Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Router i need to know how to have the router to work with the modem in order to have my d-link to work ???
  • 126 Answers
Here is a link to the Quick Installation Guide.
Posted on Feb 20, 2009
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
Electricity went out in my home and now my computer will not connect to the internet. I checked with my internet server and the problem appears to be with the router. I have a D Link N150 home router. Can...
Ok...the first thing to try is to power everything down....modem, router, and PC.
Then power them back on in this order: Modem (wait for lights to go solid) then Router (again wait for solid lights) and then PC.
I am assuming you are trying to connect wirelessly. So if it's not working on wifi, try it plugged in using an ethernet cable. Make sure that the connection from your provider comes from the wall to your modem, then from your modem to router, and from the router to your PC.
If you can't get a connection wired, take the router out of the mix. Plug your PC directly into the modem. (rebooting them both in the same order that I mentioned above.)
If it works with the modem, then the problem is with your router. You may need to press the reset button for 30 seconds or so and start over with a fresh configuration. If the modem connection does NOT work, you may want to get on the phone with your providers support team to check the connection coming to your house.
May 17, 2011 | D-Link Wireless N 150 Home Router 4Port...
Connect to dsn modern and it will not connect to internet
Your modem most likely needs to be powered-off for about 15 minutes in order for the NVRAM to clear the MAC address of the device that you previously had connected to it.
Unplug the power cord from the modem and wait about 15 minutes with the power off. After the 15 minutes, connect the router to the modem with the Ethernet cable and plug the power cord of the back in to the modem. One the modem has completed its startup, it should then work with your router.
If this does not work, then you may need to call your ISP to have them remotely clear the old MAC address from the modem so that it will work with your router.
Dec 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I do know if im supposed to connect my router to my modem in order to get an internet connection on both computers in my home
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 24, 2010 | Dynex Computers & Internet
Unable to connect wireless router to cable modem
try this website has wizard to make sure you have set it up right: if this doesn't fix problem return for replacement
Jul 20, 2010 | D-Link DI-634M Wireless Router (DI634M)
Issues with a D Link WBR 1310 Router
through the modem.
Apr 25, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Di-524 router problem
You do not need a password for cable. You need to make sure that your router is using DHCP. Whenever you connect something to your cable modem, you MUST turn off everything. Then turn on in this order:
1 Turn on cable modem and wait until the modem syncs with your ISP.
2. Turn on your modem and wait until the router and the modem sync up.
3. Turn on your PC
Your cable modem will remember the MAC address of the last device that was plugged into it, which is why you must turn off your modem to clear out the modems memory.
Jun 04, 2009 | D-Link AirPlus DI-524 Wireless Router
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DIR 300 router - Status LED and router doesn't work
Hi! I have a D-link DIR 300 wireless router.. I have the same concern before. what I did is, I did the hard reset by pressing the reset button for 20secs and after 20secs and the reset button is still press, I unplug the power from the back of the router and after 2secs plug in while reset button is press and press it for 30secs.. after that I unplug the power and plug in after 15secs. It should work, then u need to setup again the router in order to talk to the modem, if not.. and the device is still under warranty it needs to be replace...pls call your router manufacturer for replacement or if its still under 30 days, go to the store were u purchase the router.
Dec 17, 2008 | D-Link DSL 300 Modem
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
180 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
