Question about KitchenAid KSRS25IL Side by Side Refrigerator
Icemaker not working.
I replaced the filter, still it does not work at all
  • buckurt Feb 09, 2009
    My ice maker and water do not work. I changed the filter. When the ice maker calls for water, water sprays all over behind the refrigerator.
  • Anonymous Feb 18, 2009
    ice maker not making ice. replaced filter but still not working.
I just had the same problem. I found a small amount of ice formed under the water inlet point in the ice maker tray. This ice prevented the rotation of the "ice cube ejection fingers" so it couldn't cycle and re-fill. I used a hair dryer to melt this ice and the fingers immediately began rotating. Once they cycled, the tray filled with water as it should. All seems well now.
Posted on Feb 21, 2009
    Problem Solver:
  • 10 Answers
Sounds like one of the following:water valve is bad, water line connection at teh water valve is leaking, or a line from the water valve to teh ice maker near its connection to the water valve is leaking.Pull the fridge out where you can see the area where the water line enters the unit.Watch it and see where the water sprays from.If you are unable to figure out how to stop a leak after you find it, repost.
Posted on Feb 16, 2009
JJDown75
  • 8 Answers
SOURCE: icemaker
make sure the Tube to the Icemaker is Defrosted... got to make sure it is clear from ice. you might have to replace the Water Valve.
Posted on Apr 15, 2008
daddy1264
  • 76 Answers
SOURCE: replaced water filter now icemaker not working
check to see if the direction of the water flow is correct on the filter
Posted on Dec 31, 2008
  • 12 Answers
SOURCE: Water and Icemaker do not work
Sounds like you need a knew water valve. It is located on the back lower left corner of the fridge.
Posted on Jan 31, 2009
  • 531 Answers
SOURCE: Icemaker not working
check icemaker
Posted on Apr 07, 2009
EllaWatson25
  • 725 Answers
SOURCE: My icemaker is not working.
Your ice maker has gone out and this is a simple repair to make. Just contact us at :
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST when you are ready to repair this and we will send instructions along with the part.
We look forward to getting you buckets of ice again soon. Thanks, Ella
Posted on Nov 13, 2009
I have a Frigidaire refrigerator model GlH565ES. It will not make ice.
Did the icemaker work before you replaced the filter?
Oct 27, 2012 | Refrigerators
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Jan 07, 2010 | Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
It stopped making ice but cold water option works fine. No clogs visible. Changed cold setting to 7 from 5. Nothing worked. just took out water filter, but can't see how that was the problem.
Put the filter back in . Pour about 1/2 cup of water into icemaker . If it dumps , then replace the water inlet valve . If it doesn't dump and the ice stays in the icemaker , replace the icemaker . Also , make sure the coils are clean of dust etc... Reset the controls back to normal or you could create water freezing in door (dispensor) .
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
There is water to icemaker but it does not make ice.
Check if the icemaker inlet valve is opening and if the icemaker solenoid is working.
If the icemaker has a filter also replace the filter.
May 22, 2009 | Refrigerators
Jan 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Replaced water filter now icemaker not working
Dec 31, 2008 | Maytag MSD2456G Side by Side Refrigerator
KitchenAid KSRS25IL Side by Side Refrigerator Logo
528 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
