Question about Acer TravelMate 5520 Notebook
I have a problem with the right hand speaker
The right hand speaker no sound but on the output socket i have stereo
    Novelist:
  • 170 Answers
This can be a faulty jack socket on your laptop, i.e. has been knocked a couple times with the jack. to test wiggle the jack till other speaker pops in. if this doesn't work switch where the speakers attach to if the right hand speaker starts to work through the left channel then their is issues with the right channel, try switching the aux lead if it comes back then its just the wire if not it can either be your jack socket on the laptop or a blown connection on the speakers.
you can pay for people to repair these but your looking at least 100 labour and parts
Posted on Dec 20, 2013
No bass in righthand speaker
First try swapping the cables and put the left speaker cables in the right hand amp output and the right speaker in he left output. If the problem stays in the right hand speaker and does not move to the left as I suspect should, then it is a problem with your speaker crossovers. You may have to open up the speaker and check the wiring and then crossover. If the problem changes and appears in the left hand speaker you have an amp problem.
Jun 08, 2014 | Mission M73 Main / Stereo Speaker
Can't get sound thru my stereo and stereo speakers
If it is just the sound from the computer then if you have windows look for the little speaker icon in the bottom right corner of the screen, right click this, select "Sounds" then select playback (while connected to the tv) and chose the tv as the output device (set to default).
If on the other hand the issue is with the tv at all times then try going into the menu settings of the tv and looking for the various sound options. Possibly the remote control will have an audio button that scrolls through various audio options (two circles followed by roman numerals?).
Hope this is of some help.
Nov 22, 2013 | Televison & Video
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
I cannot get sound from my speakers. There is one prong on my right hand speaker but I do not know where to hook it.
Usually, the "line-out" from your computer's sound-card is a "stereo" output, but the cable only runs to one speaker.
Be sure to connect to "line-out" or "speaker-out",
not to "line-in" nor to "microphone-in".
A separate cable runs from that one speaker to the other speaker, using that single wire that you mentioned.
Sep 26, 2010 | Dell A215 Computer Speakers
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
How do I use altec lansing acs40 with a laptop?
Fairly easy really. You'll need to buy a jack to jack AUX cable. Single point for stereo needed and a headphone jack on the laptop.
The left hand and right hand speakers are slightly different. The right hand speaker only has a cord coming out the back of it and no AUX points.
The right hand speakers has a series of small jack points.
The first hole is the adaptor plug that has to be plugged into mains socket, then the 1st hole marked SPKR has to have a jack to jack cord going from that speaker to the other one. The last two holes marked "A" and "B" give you the option to put two jack to jack AUX sound cables in.
To get it into your laptop, you'll need ONE AUX jack to jack cable and fit it into the point at the back marked "B" and then through the headphone socket on your laptop. You will then have sound.
Make sure to remember to put the system on by the push button switch on the back of the left hand speaker. The speaker system also has another rotary switch on at the front of the speaker.
I've had these speakers for well over 10 years - brilliant sound quality and very durable. Hope it has helped you!
May 04, 2010 | Altec Lansing Multimedia Computer Speakers
Just need to know how to hook up proper for stereo sound
start with the right speaker, that is you control for now. plug in the power supply one end to the wall the other to the right speaker, connect the left and right speakers, connect the sub woofer to the right speaker, (most of the plug and sockets are color coded, or at least different sockets sizes so they will only fit properly with the correct connector) now you should have one wire left coming out of the right speaker-that gets connected into the GREEN socket of you computer.
Now you should get sound...good it works.
From here we go to START->SETTINGS->CONTROL PANEL->RIGHT CLICK ON SOUND AND AUDIO DEVICES->VOLUME TAB->ADVANCE (TO THE RIGHT OF SPEAKER VOLUME->SPEAKER SETUP->FOR THE DROP DOWN ARROW SELECT DESKTOP STEREO SPEAKER->APPLY->OK
And that my friend is properly done.
enjoy,,, please leave a rating, thank you
May 10, 2009 | Computers & Internet
Adding Surround Sound to Sharp 32R-S50 32" TV
if the tv has outputs at the back for surround speakers then you can connect it to them..else pass the audio of your TV thru a home theatre surround receiver
Mar 05, 2008 | Sharp 32R-S50 32" TV
Connecting Durabrand SA51AR to computer
Each "red and white" represent a stereo pair (Right and Left respectively. What type of connectors are on the SA51AR? I will guess TS (tip sleeve) or Phono for the sake of this answer.
It sounds as if the PC's outputs are stereo TRS (tip, ring sleeve) 1/8" female connectors, which is normal. TRS connectors carry both the Left and Right signals whereas Phono and TS only carry one signal each.
Radio Shack has converters which will allow you to plug a "red and white" connector in one end (either TS or Phono) and will provide a TRS output on the other which will plug into your PC's sound outputs. That way, the Red/White pair for "Side Speakers" (front L/R) can plug into the one grey jack and the Rear (rear L/R) can plug into the black-jack, etc.
Feb 07, 2008 | Audio Players & Recorders
Acer TravelMate 5520 Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
