Question about Epson Stylus Photo R2400 InkJet Printer
MY EPSON STYLUS N11 WONT PRINT - Epson Stylus Photo R2400 InkJet Printer
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Posted on May 01, 2008
  • 33 Answers
SOURCE: epson stylus pro 4800 print head problem
Are you getting a nozzle check at least?
Posted on May 14, 2008
Tirzo
  • 94 Answers
SOURCE: Epson Stylus CX4800 All-In-One
One possible solution that we can advice is to do a complete trash & reinstallation of printer driver as well as the scanner driver.
For iMac with Leopard, there is a big possibility that the printer driver is not the correct epson series printer driver that's why you can't ink levels is unavailable. Just to set an expectation, printer driver for CX4800 is pre-installed as resident driver in Leopard. Please try to the following to solve that issue:
Determine Which Driver is Currently Being Used
1. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
2. In the System Preferences window, click on Print & Fax.
3. In the list of printers on the left side of the Print & Fax window, click once on your Epson printer to select it.
4. Check the name of the driver being used; it is displayed in the center of the Print & Fax window next to “Kind”.
5. If the driver name displayed next to “Kind” is Gutenprint, the incorrect driver is being used. Follow the steps in the next section to select the correct driver.
Selecting the Correct Driver
1. Turn off the printer.
2. Delete the print queue and remove the printer from Print & Fax by clicking on the minus (-) button under the list of printers. Click OK to confirm the removal.
3. Click on the Apple icon in the upper left corner of the Finder and open System Preferences.
4. In the System Preferences window, click on Print & Fax.
5. Turn on the printer. The system should add the printer automatically.
6. If the system does not add the printer or if it adds it using the Gutenprint driver, contact Apple for assistance. You may need to reinstall the Epson drivers provided with Leopard.
NOTE: To check ink levels, click the Utility button, then click EPSON StatusMonitor. The Supply Levels button will not show remaining ink levels for your Epson printer.
Posted on Jun 11, 2008
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
SOURCE: my epson dx7400 stylus printer wont print in black without all ca
how to print on epson stylus dx7400
Posted on Jan 03, 2010
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Sep 20, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus cx4600, not working
the printer wont work it will copy but not print anything off computer
Feb 01, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus cx3200 wont print good.
You're jets are pretty much shot. Have you recently used generic ink or used ink that has sat for a while? I had almost the same model and bought my ink in bulk not thinking about it and same thing occurred. Time to upgrade to a new printer...sorry.
Oct 30, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
My printer wont respond or print
Did you open it up and look for paper jammed in it, or maybe it mispulled and just needs to be reset. Inkjets are fairly simple.
Mar 23, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus cx7400 wont print but one copy at a time
Epson Stylus S20, when I alter number of copies required from 1 to say, 8, it prints only ONE. Why? wgaynair@gmail.com
Jan 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus C46 wont print
Printer will not print red and green lights on all the time
Nov 06, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus Photo R2400 InkJet Printer Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
