Question about Kenwood Car Audio & Video
Kenwood KDC-252U wont turn on
Just hooked up new stereo unit has power to it but wont turn on
shagone
  • 34 Answers
SOURCE: UNLOCK SECURITY CODE
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Posted on Jan 08, 2009
  • 132 Answers
SOURCE: My car stereo
In standby hold the menu button down untill menu pops up, the use the up down left right and pushing of the joystick to select clock ans set it :)
Posted on Jul 25, 2008
  • 22 Answers
SOURCE: I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
http://inform3.kenwoodusa.com/manuals%5Ckdcx492.pdf
Hope this helps.
Richard
Posted on Mar 10, 2009
  • 773 Answers
SOURCE: I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Posted on Dec 15, 2009
  • 111 Answers
SOURCE: My Kenwood KDC-241 car stereo loses it memory when
you need to rewire it,it seem like you connect the YELLOW (memory wire)to the ignition line.
You will need to connect it to constant pwr line and the RED to the IGNITION line
Posted on Jan 22, 2010
New radio in truck wont power dont when truck is off
There are two 12 volt sources from the vehicle behind the stereo, one is a constant which the stereo requires to keep the clock circuit powered, the other is a switched ignition source which is designed to supply power to the stereo when the key is turned backward from the off position and or forward, you likely connected both wires from the stereo to the constant wire. Perform a Google search to obtain a wire color diagram of your vehicle.
Dec 22, 2013 | Radio Communications
I hook up a new stereo to my car it works great but when i turn car off and i wait for a while start it back up the stereo would b off n i would hve to put the power button to turn it back on what i do...
radio has to be factory radio because factory radio is programmed to vechicle PCM and theft security system any kind radio wont work with your vechicle has to be factory model radio has to be reprogram.
Oct 22, 2013 | 1997 Volkswagen Jetta
Wire diagram vw caddy van for stereo
As you have power to the eject and cd, it would seem to be a problem with the Power switch on the head unit.
Jul 14, 2013 | Vehicle Parts & Accessories
Why wont my stereo wont turn on
make sure you have a good ground and 12 volts on the power wire.the problem is in the way you are wiring it if the unit works when hooked to a battery.
Jun 14, 2012 | Cars & Trucks
So i just hooked up my stereo in my 1998 lasabre and now my rear defrost isnt working and my heater isnt working right which wires do i still need to hook up and to what?plz
Okay you stereo took power from the heater control this only proves that power should be independant and a dedicated line for the stereo.Your stereo probable draws more current that what was in there before. what wire should you hook up a new line2_25_2012_5_12_47_am.gif2_25_2012_5_13_37_am.gif
Feb 25, 2012 | 1998 Buick LeSabre
I have a 95 nissan maxima i am trying to replace stock radio(bose) w/a new cd player but once its hooked up im not hearing any sound? whats wrong with it?
Most Bose car stereos have an external amplifier. You will need to see if that is the case on your factory setup and remove the amplifier. Then hook the new headunit straight to the speakers.
May 30, 2011 | Car Audio & Video
My stereo wont turn on i dont know what the
hook up the ground and twist the red and yellow together and hook that up to a wire off the battery then try and see if the head unit comes on quick way to check and see if the deck will come on works for me. hope this helps,
May 10, 2010 | Alpine CDA-7892 CD Player
Power to unit and well grounded but wont turn on
There are 2 powers for this stereo. The is a constant power (yellow wire) which holds the memory, then there is an ignition power (red wire) that turns the stereo on when you start the car. Some cars you need to run the red power wire to a fuse that only works when the car is turned on, for example power windows. Only run it to a fuse that is equal to the fuse on the back of the stereo ( more than likely 10a). Oh and btw check the fuse on the back of the stereo under the plug. If none of these work you have a bad stereo. Or you hooked up the wires wrong.
Mar 14, 2010 | Pioneer DEH-P2900MP CD Receiver...
Dash lights, dome lights and stereo quit workign when installing
You probaly fried the dimmer switch, I did the same thing to mine. All i did was eliminate the switch. I cant change the brightmness but they do turn on.
Jul 11, 2009 | 1995 Geo Tracker
Will not power on
Try taping the ground wire directly to the negative battery terminal, and the positive and RMT wires to the positive battery terminal, if the unit still won't turn on, check for a fuse on the unit itself, otherwise it may be dead on arrival.  If it does work, check all your car fuses, also look for inline fuses on the stereo live wire harness.  Hope this helps
Oct 29, 2008 | Car Audio & Video
Car Audio & Video Logo
261 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
