Question about Homelite Plumbing
Pull cord replacement for ap125 gas watwer pump
How can i replace the pulluing cord for this pump
4 Suggested Answers
SOURCE: Fuel Pump Replacement
On a 1996 Jeep Cherokee you have to pull the fuel tank.I am not sure on your model. It is not very hard to do. The tank on my vehicle is plastic and is held on by straps. Just put a jack under the tank and loosen the straps. As you lower the tank you can get to the connections to unplug the wiring. Once you have it on the ground, the fuel pump has a retaining ring that holds it in. It will unscrew and the fuel pump will come out.
Posted on Oct 04, 2008
erickg
  • 116 Answers
SOURCE: REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Posted on Apr 17, 2009
  • 5 Answers
SOURCE: pull cord broke on my craftsman gas push edger. I
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
Posted on May 06, 2010
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
On my top load washer when it goes into a spin mode everything is real wet at end of cycle and there is water running on the foorwater seems to be coming some where in the back and watwer doesn;t drain but...
Might be the seal on the pump itself. If water is coming from underneath the unit, more than likely it's the pump seal. Very common problem. You'd be better off replacing the whole pump and not just the seal. Less trouble that way.
Sep 04, 2011 | Frigidaire GLWS1349A Top Load Washer
Parts for AP 125 water pump (Homelite ) that is no longer being manufactured.
Homelite still has some parts for this pump
go to http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
search for AP125 with no space
pick your model
parts list will come up
Jun 27, 2011 | Homelite Plumbing
Won't start. Pull chord will only come out quarter of the way.
There could be two possible problems here.
1) Usually you want to squeeze the gun trigger to release backpressure on the pump so the engine will turn over easily. So hold the gun in one hand with water coming out of the gun while pulling cord.
2) The pull cord mechanism is connected to top of power washer with 3-4 bolts.
Take off those bolts and see if you can unravel the problem. The mechanism is connected to a spring and the spring pulls the cord back in ... so it seems like the rope is in a bind or the pull mechanism is bad.
We had to buy a replacement pull cord mechanism at one time for our power washer, but I forget exactly why it stopped working. We used the power washer two days a week for years. It's aggravating when it doesn't work.
Oct 17, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Chevy venture can
Locate the radiator, you will see a hose leaading into the engine. Trace this hose to shere it enters the engine. There should be two bolts, loosen these pull the hose up and you will se the thermostat. Befoe replacing it. Place it in some boling watwer, if it opens, the theromstat is not defective.
Jun 12, 2009 | 2003 Chevrolet Venture Passanger
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Plumbing Logo
Top Homelite Plumbing Experts
richie46
Gil Shultz
Robert Dean
Robert Dean
Level 1 Expert
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
