Question about Maytag Dryers
Maytag lde 490 squeaks louldly, what's the best way to open it up and check it out
What should I look for
3 Suggested Answers
computer dav
  • 3 Answers
SOURCE: Drye squeaks louldly and smells hot drum stops turning
you have a drum ball that is chrome looking that fails a lot
you need to get the kit and direction from a parts house to fix it ..
mine breakes about every 6 mo
5 boys in the house
Posted on Jun 08, 2009
SOURCE: Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Posted on Jun 19, 2012
Jun 19, 2012 | Maytag Dryers
My washer when on spin make a very lould noise. like maybe a bearing is out it is a magtag neptune front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Maytag Dryers
L have a older maytag lde 410 the drum is hard to turn after the belt came off can you help us please
here is a descent website, Hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 19, 2010 | Maytag MDE8757AY Electric Dryer
Maytag Dryer Model #LDE 4916 ACE. Dryer won't start
Sorry, no reset button. If it ran a bit without the belt, it may have overheated and blown one of the thermal fuses. You can find schematics and diagrams at
www.appliancepartspros.com
Good luck.
Mar 15, 2010 | Dryers
5 boys in the house
Apr 02, 2009 | Kenmore Dryers
4 wire cord for Maytag lde 410
There is usually a metal strap or a wire from the enter terminal to the dryer cabinet. Remove and discard that. Attach the green (ground) wire the the cabinet. White (neutral) to the center terminal, and red to one of the other terminals and black to the other. (both are "hot" wires)
Feb 06, 2009 | Maytag Dryers
Squeak
Lubricate the chrome rail with 3 in 1 oil that the print head moves across on.
Jan 06, 2009 | OKI MICROLINE 490 Matrix Printer
NEED TO REPLACE BELT ON MODEL lde 412 series 02 serial no. 618 889 PX
its a maytag,
LDE 412 series 02, the labelling printing machine at Maytag is notoriously crappy
Unplug dryer
Remove two screws at bottom edge of front panel, under the lip facing up so they are hard to see.
  • May be TORX secure screws(star shap with a pin in the middle), TORX secure bits ~$6 at good tool shops, or cut a slot across the head of the screw and use a flat blade, throw the torx away and replace with phillips head screws, easier for next time
tilt front panel up from the bottom and unhook it from the catches
undo door switch cables
place door aside
lift drum out
motor, belt, bearings, felts, are all easily accessible.
check felts and roller bearings before you put the case back on, often a seized bearing is cause of belts breaking
While you have the case off pull all the lint n **** out of vent and motor area
Aug 25, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
