Question about Comfort Zone CZ7007 Oil Filled Electric Radiator Heater
Won't heat my studio - even on "HIGH"
I just bought a Comfort Zone CZ7007 and with both switches "ON" and knob on high, it does not heat my 20 x 15 foot studio. What's the problem?
    Genius:
  • 1,669 Answers
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
Posted on Jan 01, 2013
3 Suggested Answers
SOURCE: how do you turn on
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Posted on Jan 14, 2011
  • 383 Answers
SOURCE: Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
Posted on Jan 15, 2011
I have been using my heater in the garage to prevent my water pipes from freezing. It just quit working today. The lights do not light and it will not heat any longer. What happened and what can I do to...
Have you checked the circuit breaker or fuse for the circuit that your heater is on? It's possible that you had something else come on that, combined with the current draw of your heater, popped the breaker. If that turns out to be the case, turn the heater switch from high to medium or from medium to low so that you're drawing less current.
Feb 24, 2015 | Comfort Zone CZ7007 Oil Filled Electric...
Just want the manual for CZ7007 - do not have one
Heaters Comfort Zone from Howard Berger
here is the website for the manual. just look for the model you have.
Google is your friend.
Nov 14, 2014 | Comfort Zone CZ7007 Oil Filled Electric...
My Comfort Zone Oil filled CZ7007J Radiator is not heating, it was working just fine when I turned it off, but when I turned it back on, no lights, no heat, like it's getting no power. Bought it
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Dec 30, 2017 | Comfort Zone CZ7007 Oil Filled Electric...
In the Comfort Zone CZ7007 is there a repaceable fuse & if so is it located above the thermostat inside the control panel cover and where can I find another. No heat from unit or lights in switch but
I''m replying almost a year later, but this may help others who are having this problem. There seem to be a lot of problems with the tip over switch in the Comfort Zone radiator heaters (this is the switch at the very top, inside the panel, above the thermostat). I had the same problem- no heat, switches weren't lighting up. I bypassed the tip over switch (we have never tipped over one of our radiator heaters, so it's not an issue) and connected the switch wires with a wire nut and then further secured the wire nut with electrical tape. Now the heater works as it should again.
Nov 25, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
When we first bought the heater the coils did not turn red but they are now . what could cause this , and is it dangerous?
when you first bought the heater even if it wasnt "red" as you say did you get heat from it? now those type of heaters are good when they work. First the heater has 2 settings say low and high now in low the wattage will turn some of the elements partly red the reason you dont see it is because it is fan forced heat on those type heaters which causes the elements to look like they are not red but they are on, only low will do this. Now high will cause all elements to get "red" even while the fan is running. If there is no heat someone needs to bypass switch to see if they work.process of iliminitation.Hope this helps for you.
Jan 17, 2011 | Comfort Zone CZ792 Electric Utility Heater
Is there a recall on the Comfort Zone CZ7007 heaters? I have two that do not work.
Tell us more--
Mack B
Jan 15, 2011 | Comfort Zone CZ7007 Oil Filled Electric...
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Logo
127 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
