Question about Homelite Plumbing
Ap-125 homelite gas watwer pump pull cord replace
    Habit-Forming:
    New Friend:
  • 9 Answers
Few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Posted on Mar 22, 2017
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: have a homelite AP-125 -
Your best bet is to ask Homelite directly for the pump curve. Since Homelite does not appear to offer it anymore I could not find anyone who published the information, hence the referal to Homelite. A typical pump curve for a small pump like this will show GPM or GPH based on several discharge heights. You do not need to consider the overall run of pipe or hose but only the total change in height. In other words, pumping thru 150' of 3/4" hose up an incline that has a total rise of 12' would end up delivering the GPM for 12' on the curve or something very close anyway.
Contact Homelite here.
John
Posted on Jan 04, 2011
  • 70 Answers
SOURCE: My late husband bought a
usually on the fuel cap it has the mixture,usually 40 to 1 is a safe bet,a little too much oil in the mix is better than less
Posted on Jun 12, 2011
  • 643 Answers
SOURCE: parts for AP 125 water pump (Homelite ) that is no
Homelite still has some parts for this pump
go to http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
search for AP125 with no space
pick your model
parts list will come up
Posted on Jun 28, 2011
How do fix a homelite mp88 portable chop saw that has been liquid locked
rey taking the spark plug out and turning it over with the cord a few times to remove the liquid from the chamber and sump
Feb 15, 2017 | Homelite Garden
Parts for AP 125 water pump (Homelite ) that is no longer being manufactured.
pick your model
Jun 27, 2011 | Homelite Plumbing
Have a homelite AP-125 - UTO1709 F, want to know how far it can pump water uphill
John
Jan 04, 2011 | Homelite Plumbing
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Aug 05, 2010 | Homelite Consumer Products MightyLite...
Need to replace pull cord on homelite z830sb
Start from the bottom and work your way up. This is not an easy repair. You have to almost completely dissassemble the entire blower to replace the cord. You will need a T20 and T25 torx tool, a 9/16' wrench or socket, 40" of #3.5 rope and about an hour. A repair shop will typically charge $20 to $40 in labor for this repair.
Jul 24, 2010 | Homelite Consumer Products MightyLite...
I have a Homelite recirc pump AP-125. Motor runs
usual if the pump is dry you need to try bleed get some water to the pump. either pouring some in the lift pipe some pumps have a bleed screw to pour into to get it pumping. if it still wont could be the fins in the pump that are not working proper
Sep 26, 2009 | Homelite Garden
Homelite AP 125 two stroke motor will not start after replacing fuel lines. There is fuel coming into the carb and into the cylinder as well. Motor will not attempt to start. Spark plug is new and has...
If you have a two line fuel system make sure the lines didn't get crossed. If they are you could still get gas to the cylinder but not enough. I hope this will of some help to you. Donnyb60
Mar 18, 2009 | Homelite Garden
Plumbing Logo
765 people viewed this question
Top Homelite Plumbing Experts
DROPNDEAL
DROPNDEAL
richie46
Gil Shultz
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
