Question about Janome Sewing Machines
Janome makes rattle when I sew
It was working fine but it started rattling In bobbin area. I cleaned lint out. Not much there.
  • Janome Master
  • 7,365 Answers
Try changing the bobbin and see if that helps
but if it doesn't help the the machine needs to be checked to see if
there is something wrong with the hook and hook race
Posted on Jan 02, 2013
sew dutch
  • 25 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 136 Answers
SOURCE: Singer 4622 drop in bobbin rattles
Recheck top threading
Posted on Jul 07, 2009
  • 52 Answers
SOURCE: it makes a rattling sound when I sew. It has been
If its an older singer featherweight it should sound pretty quiet but if its a newer 221 it has plastic or nylon gears and they can make a "barking" sound
Posted on Jul 16, 2009
  • 1788 Answers
SOURCE: Sewing machine works fine as
Go to singerco.com and download a manual for free, you are not threading it right
Posted on Aug 30, 2010
kirkx
  • 2019 Answers
SOURCE: I have a janome 8050
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Posted on Apr 08, 2011
I recently had my New Home 7500 serviced. It now has a rattle in the bobbin area as it sews. Sewing is fine unless I speed up then it might thread jam.
contact the one who serviced it and tell them that the machine is making rattling noise which it didn't do before and see what they say
Dec 08, 2014 | New Home Sewing Machines
Bobbin case
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Sep 28, 2013 | Janome Sewing Machines
My machine keeps clogging at the beginning of my sewing
Dec 12, 2012 | Janome Sew Precise Mechanical Sewing...
I have a Janome mc 6500 and the bobbin thread keeps getting stuck around the feed dogs?
try changing the needle
clean under the needle plate area for lint or threads
try rethreading the bobbin,making sure the bobbin is inserted correctly into the bobbin case.
May 16, 2012 | Janome Sewing Machines
Rattle in the bobbin area.
also make sure the bobbin fits securely in the bobbin case
does the bobbin case fit securely in the machine?
the bobbin case could be getting old & might need to be replaced.
Apr 12, 2012 | Sewing Machines
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
The bobbin (or bobbin case) rattles while sewing.
Do you have the right size bobbin inserted? Is the case inserted correctly? If these are not the problem, I would call Janome and find out what is causing this if it has just started.
Jan 03, 2011 | Janome Memory Craft 9000 Computerized...
My sewing machine is not working properly - i think i have loaded the bobbin correctly but after about 3 stiches the cotton all jams - what have i done wrong - it is not a new machine I have used it before...
put a new needle in the machine
clean under the needle plate where the feed dogs are for lint
clean in the bobbin area for lint & loose threads
also rethread the machine, make sure you get every thread guide
Nov 18, 2010 | Janome SEW MINI Mechanical Sewing Machine
Everything was fine and then there was a noise and the thread got all bunched up underneath. I oiled it and it happened again.
change the needle
check to make sure the bobbin is wound correctly & is inserted correctly
make sure to put the thread thru every thread guide
Nov 18, 2010 | Janome Memory Craft 3000
My Pfaf 1222 made a rattling noise, but was sewing. Now it jams with thread after two revolutions, need to hand turn the wheel to get it to turn those 2 turns. I broke one needle. I bent another. When I...
Check the manual for maintenance infromation.
Noise can be from lint in the bobbin area.
After cleaning, re-thread the machine with the presser foot up to see the combination of cleaning and "presser foot up" threading helps.
Mar 29, 2010 | PfaFF Tiptronic 2030
Sewing Machines Logo
299 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
