Question about Sony Playstation 3 (PS3) Console
I cant start up my console
When i turn on my ps3 console the power light comes on when i hit the power button for the console to come on it turns green then immediately back to red and the console beeps and turns itself off and
leaves the red light flashing, the light initially goes green and then yellow then back to flashing red
  • 3 Answers
Same problem gonna fix tonight let u know how it goes
Posted on Aug 02, 2010
    Sniper:
  • 85 Answers
Your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up. Also i run a home based computer repair business in southern California. Feel free to email me at dwdpcrepair@gmail.com.
Posted on May 17, 2009
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
When I hit the power button it beeps then cuts off
are you holding it down when you do it if thats the case then as soon as it turns green then remove your hand from it
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
Hi There,
Your Processor needs reflowing (re soldering on the board) as the system over heated, it caused stress on the solder joints underneath.
Sony charge £150 and give a month warranty to repair it.
We charge £60.00 and give a 6 month warranty.
FixMyConsole
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 power wont turn on at all? i hit the switch but???
man i dont know what to tell you but to change your hard drive and and or get a new ps3 dude
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Hi when i turn on my ps3 corrupt data comes up on screen and when my ps3 trys to fix the problem it just goes back to the start again i cant even get into the main menu its 2 years old was kept like new i...
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Try this and get back with me, I will look into it for you.
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
196 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
