Question about Fujitsu 18,000 Btu/h Dual-Zone Mini Split Heat Pump System - AOU18RLXFZ
Fujitsu error code 94 "trip detection"
What is tripped, causing this code & what needs to be done to fix it?
2 Suggested Answers
SOURCE: fujitsu a/c ast24rsg-w blows fuse after 3 mins as comp starts up
My unit is doing the same thing. Have you found a solution yet?
Posted on Jul 20, 2009
My Rinnai tankless water heater keeps tripping the breaker then when turned back on, it begins to beep and displays a code 12. What is causing this? It is new and this is the first time any code came.
Go to Rinnai and get a manual with the error codes... for example a shorted element will trip breaker... wiring problems can cause breaker to trip... anything that causes heat on wire to exceed amp rating of breaker will cause it to trip...
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Sep 12, 2017 | Rinnai Water Heaters
How do i fix my dewalt 55155 air compressor
It is a 15 amps motor and will need 6 times (90) that amount of amps to start up. Plugging it into a 15 amps circuit may work but a 20 amps circuit is more apropiate. Kitchen circuits are 20 amp circuits.
You can try plugging the compressor directly into the wall and see if it refills with air without trippiing the circuit breaker. Using an extension cord should be done with a #12 or #10 wire gage type, smaller type will cause a power loss in the cord and will cause the compressor motor to trip the circuit breaker.
Power formula is I square R, or the amps multiplied by itself and by the resistance of the wire. E.G. 90x90x4 = 3200 watts. This is at start up. To find the voltage drop divide the watts by current, 3200/90 = .... get the point? Keep voltage drops to a minimum, use heavy wire gage extension cords.
Mar 11, 2015 | Dewalt Air Tools & Compressors
How to reset maintance light on 2009 Toyota truck
HELLO IT REALLY DEPENDS ON WHICH LIGHT ONE IS ASKING ABOUT.YOU WILL BE NEEDING A OBD 2 CODE READER . SOME ARE NOT ABLE TO READ THINGS LIKE ANTI LOCK BREAKS LIGHT AND SUCH. YOU'LL NEED TO READ THE CODES AND CLEAR THEM BUT UNLESS THE PROBLEMS YOU HAVE SENDING THE CODE TO IS NOT FIXED THE CODE WILL BE COMING BACK AS FOR THE LIGHT . MY CODE READER WAS JUST OVER 2,000.00 AND YOU NEED A WIRELESS HOOK UP FOR MINE TO WORK RIGHT. TO IT GETS TO THE POINT AND WHAT REALLY NEEDS TO BE FIX QUICK ,
Feb 27, 2015 | Toyota Cars & Trucks
I need to know what the code for a 1993 honda accord it flashed 4 slow then three short fast flashes, my car has been lagging really bad and i dont know exactly what i need to do to fix it i was told it is...
Found this for you on the web. Good luck.
c/p;
What is code 43?
Code 43 is "fuel supply system."
This code will trip when the ECU and the readings from the o2 sensor don't get along(in layman's term or easy enough for Si Speed to understand biggrin.gif) read the above two threads).
How to diagnose and fix?
First things first, when was the last time you changed your O2 sensor? Start by replacing that first because most likely, that's the main culprit. Now, you may wonder why doesn't the CEL indicate code 41(heated o2 sensor)? Usually when the o2 sensor is completely dead, that code will trip. Also, even though the o2 sensor is working, the voltage or ground isn't 100% Because of that, it will correlate with code 43.
If replacing the o2 sensor did not help code 43 to disappear, next thing is to replace your fuel filter. A clogged fuel filter will also trip code 43.
Next up, did you install an aftermarket Fuel Pressure Regulator? I have a few friends with 3rd gen Preludes and both of them installed aftermarket FPR's and they too, trip code 43. Him and a lot of people who install aftermarket FPR's mess with the PSI and that will cause code 43 to appear(on a stock ECU mind you). Bring it back to stock PSI to help fight code 43.
Those are the 3 main culprits that will cause code 43 from my experiences. Injectors, spark plugs & wires, most likely anything "fuel' related that isn't working properly will also cause code 43.
May 03, 2011 | 1993 Honda Accord
HOW DO i FIX THE CL CODE
Cl Average current limit Or
Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Press STOP/CANCEL to clear the display
Nov 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Engine
Hi:
You need to have your Toyota scanned to see what code is causing the light. There are hundreds of codes that trip the light, some so simple as a bad or loose gas cap. Most auto parts stores will scan your car for free, such as Auto Zone. That way you can pinpoint the source of what is tripping the light and go forward from there. It is most likely not related to the work you have done, unless you have a connector that you have knocked loose or similar?
Apr 22, 2010 | 2004 Toyota 4Runner
How do i fix my kemore elite calyspo.with code ca flashing
how are u am scott hope i can help ok i have the same washer this CA code means AVERAGE CURRENT LIMIT, OR INSTANTANEOUS CURRENT LIMIT. if a status comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip, or "CI" for instantaneous current limit trip. AVERAGE CURRENT TRIP occurs if there is a 2-second average of current draw greater than 5.55 amps at the motor windings. INSTANTANEOUS CURRENT TRIP occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. or overloading the unit may cause this problem. press stop/cancel to clear the display good luck
Feb 17, 2010 | Kenmore Washing Machines
C A code repeatedly occurs, I have cleaned the
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "CI" for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 Amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector or motor controller. Overloading the unit may cause this problem.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
Jan 18, 2010 | Kenmore 22062 Top Load Washer
Washing machine pulls ca then c1 code. seems to be the calypso action problem. does it need a new motor
The C1 code signifies "Average current limit Or Instantaneous current limit."
display either CA for average current limit trip or C1 for
motor controller. Over-loading the unit may cause this problem. "
Please check down the drive motor to resolve the issue.
Have a blessed day!
Thanks!
mannu_rakesh
Sep 01, 2009 | Washing Machines
Kenmore washer model # 110.24086200
The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
Fujitsu 18,000 Btu/h Dual-Zone Mini Split Heat Pump System - AOU18RLXFZ Logo
326 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
