Question about Craftsman GT 5000 26 HP54" Garden Tractor ()
Need to adjust valves 26hp briggs strat eng - Craftsman GT 5000 26 HP54" Garden Tractor ()
How to adjust vales on 26hp brigg s. ov
Will need "Model" Type" and "trim" Number from the Nameplate located on Engine metal cover. Example 310700, 0137-E1
Jul 11, 2014 | Briggs & Stratton Garden
Need valve clearance on Briggs eng. Mod. 407777
Set No. 1 cylinder at 1/4" past TDC (Top Dead Center) on compression stroke. Gap both valves at .005". Gap is set with the engine being cold. Do the same for the other cylinder. Be sure to lock the adjusters back in place.
2. .S
Aug 07, 2013 | Briggs & Stratton Garden
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
Briggs & stratton 26HP engine is reving up and down after 30 min
I removed the engine and broke it all down last night. Inside the engine I found a mole. Once I removed the live mole and cleaned the valves - it worked fine.
May 13, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Mar 07, 2009 | Briggs & Stratton Garden
Craftsman GT 5000 26 HP54" Garden Tractor () Logo
46 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
