Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer Ld code?
I have a Calypso washer that won't complete cycles. The clothes are not rung out. Does not seem to start its spin cycle, and lots of water left below agitator. When it stops it gives a "Ld" error code. Any idea where to start?
  • Anonymous Jan 20, 2009
    my washer is displaying FL and some water remains . clothes are not completely wrung out
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Posted on Jan 25, 2009
  • 198 Answers
LD means long drain, either your pump is bad or it is clogged
Posted on Jan 21, 2009
I recently had the same problem. I actually took the two hoses off of the pump and found a penny in their. It was actually difficult, I couldn't figure out an easy way to get the water out first and had quite a mess. But now the washer works again.
Posted on Feb 22, 2009
    New Friend:
I have the same problem, but how do you unclog it? Please explain. I have the washer completely disconnected and I unscrewed the back door, but I don't know what I'm looking at, but I can see there's still quite a bit of water left inside. Thank you!
Posted on Jul 30, 2015
  • 3 Answers
What means ob code
Posted on Jan 09, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washer beeps Ld a few minutes into each wash
LD means = Long Drain
Problaby samething inside the pump
Is your machine calypso
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Ld and ob codes
LD code means your pump is cloged with lint or small piece of clothing such as a sock. I had the same code on my washer and sure enough i found my pump cloged with lint from a blanket my wife washed. hope this helps. sorry I cant help on the other code.
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
1,725 people viewed this question
Dan Webster
Dan Webster
Sal De
