Question about GE Spacemaker JVM1640SJ Microwave Oven
My ge senor microwave oven model number wes 1450dn1bb quit working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Check the fuse. Bad? Test the door switches and replace the bad one and then the fuse.
Posted on Sep 23, 2014
vitg55
  • 70 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You should be able to get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jun 08, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: WHat part number for this GW Microwave oven thermostat?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It will tell you where each one is located and what it's called, and should have the part numbers.
Three of them should read normally closed and one should read open.
If you still need help, let us know.
Posted on Jul 05, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
I have a GE Microwave Oven, on the owner's manual it has this under the word owner's manual WES1450DMBB on the back of the oven this is what's there 812TAAC20736 & G9-8DE00780-020736. My...
Unfortunately, the GE WES-series ovens made for Wal-Mart were apparently made to be thrown away if they failed out of warranty.
GE only makes available the turntable tray and roller ring, and no other parts.
Jul 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave Model #JE1860BH 03 will not heat. It started to arc for a few times then quit heating. Everthing else works. Can you help?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave quit working on wall unit with oven below. The model # is GE JKP69
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works, sounds normal, but it will not heat anything.
Owners of a GE WES model might want to look at this blog post.
Hopefully its still under warranty.
If so, GE Customer Service is here.
If not, I'd replace the oven.
Jan 08, 2010 | Jenn-Air JMV8000 Microwave Oven
Microwave Model WES1450DM1BB I boiled 4 cups of
I'm sure the magnetron overheated and tripped the magnetron's thermal cutout.
I'd strongly suggest taking it back if you can.
Dec 24, 2009 | GE Microwave Ovens
GE Microwave wes1384sm2ss quit cooking. it
Nov 28, 2009 | GE JE1640 Microwave Oven
Counter top microwave GE lost all power
As an owner of a GE WES model might want to look at this blog post.
Good luck.
Dec 16, 2008 | GE Microwave Ovens
Won't shut off
Chances are you have a shorted door switch, but all owners of a GE WES model might want to look at this blog post.
If it's been less than 30 days since you bought it, I'd hurry and take it back to the dealer for a refund, not an exchange.
Otherwise, GE Customer Service is here.
Oct 09, 2008 | Microwave Ovens
Ge WES1450DM1BB serial RM913001U mirowave will not heat
Owners of any GE WES-series microwave might want to look at this blog post.
GE Customer Service is here. I would contact them.
No parts are available for this model besides the turntable parts. Scary...
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 21, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
93 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
