Question about Drills
Toyang motor in drill press won't work
It only hums when turned on
3 Suggested Answers
  • 4088 Answers
SOURCE: 1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Posted on Aug 23, 2009
Obertelli
  • 3006 Answers
SOURCE: drill press motor hums and barely turns
The motor has either got worn brushes or more likely the windings have been attacked by moisture and gotten the dreaded "green spot" (corrosion).
Worn brushes can be replaced if the commutator is still good. But failed motor windings require a new or reconditioned electric motor.
Posted on Mar 12, 2010
Found a used Home Master KFF6 Drill Press; thought I scored big when I got it for $50. Motor hums, spindle and chuck don't turn. Can I troubleshoot and fix myself, or can I get it repaired in CT?
The humming motor is that it could not get a turn direction because of only ac and a bad centrifugal or start capacitor if it hums try to turn it clockwise on the chuck to see if it will run .
May 13, 2016 | Drills
GE Dryer GFDN110ELWW hums loudly and won't start
The start capacitor is built into the motor and you will need to replace the motor. Here is the motor if you should need it.
Nov 24, 2012 | GE GFDN110ELWW Electric Dryer
My dryer was in the rain and now won't work...just hums
If the motor just hums and it will not rotate the drum, you will need to replace the motor. Here is the motor to order.
Nov 18, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
Jacuzzi 1hp hums won't turn on
If your motor is turned on and just hums then it is bad and will need to be replaced.
Rod
US Parts Center
888-521-6183
May 29, 2012 | Jacuzzi Impeller, L - 3/4 H.P
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
Drill press motor hums and barely turns
Mar 12, 2010 | Delta Drills
Aug 23, 2009 | Drills
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Drills Logo
188 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
