Pro Temp 70,000 btu forced air heater works fine until reaches set heat, thermostat shuts off properly. a few minutes later, after a temp drop and thermostat turns heater back on, heater starts and w
This item is only two weeks old. It used to run the second time for about thirty seconds before shutting down and the light would not blink, so, a few minutes aftet that it would run again for antoher thirty seconds, and continue doing this through the night, but now It runs once properly until set temperature is reached, then shuts off, and on restart (about 5 minutes later) will run 18 seconds then shut off, light above thermostat blinks and heater will not reset itself. Power must be shut off and back on.
  • 579 Answers
SOURCE: Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Posted on Dec 31, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: BLOWER CONTINUES TO BLOW COLD AIR AFTER REACHING DESIRED TEMP.
There is a little switch on the circuit board. Look closely at the wiring diagram and it will indicate which switch to adjust. If not, review the operating manual for details.
Posted on Nov 25, 2008
mrgrzz
  • 88 Answers
SOURCE: furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Posted on Jan 20, 2009
  • 2820 Answers
SOURCE: Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Posted on Feb 28, 2009
  • 68 Answers
SOURCE: Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Posted on Aug 03, 2009
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Rinnai Avenger 25...Thermostat is on 26 but the room is no where near that hot??
the heater will attempt to heat the room until temp is reached if door is opened or cool air enters the heater will continue to run if the heater is set to 20 when the room reaches 20 the heater will shut down until temp drops below 20 then restart
Jun 12, 2011 | Rinnai Heating & Cooling
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Nov 21, 2009 | All-Pro Propane Garage Shop Heaters - All...
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Open limit switch
Tjere is a limit switch that will only allow the durnace to reach a certain temp by kicking on the fan. The thermostat being unable to read the temp affects its ability to keep the furnace from exceeding your settings. *Advise not to use until corrected. Both limit switch and thermostats are inexpensive and simple to change. If in doubt, call a heat and AC tech to repair.
May 18, 2009 | Coleman Propane Forced Air Heater...
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
