Question about XION _ Solaris XON-407 ATX Mid-Tower Case
How do you hook in the front usb plugs into a asus motherboard?
  • 1 more comment
  • Frank James May 11, 2010
    Need to know what motherboard also. The board you have may not support additional USB other than onboard.
  • junior xrtes May 11, 2010
    Check out the manual that came with the board  it usually tells you
  • Jay
    Jay May 11, 2010
    how does the front USB plug look like? is it a square plug or in a string with different colors like red, white, green, black?
Most Asus come with a blue little hub with 9 pins connect the front usb there and the GNd Ground 2 :D
Posted on Feb 13, 2010
  • 948 Answers
You need a separate cable, called a USB header. It plugs to the connector in the case and onto your motherboard. A lot harder to find that you would think too, my top ports still are not hooked up after several years.
Posted on Jan 24, 2009
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
How to connect front usb to motherboard
First need to check front usb cable attached on mother board usb plug or not if its not attached so plug in to this pannel and then after you can access it.
May 09, 2010 | ASUS P5PE-VM Motherboard
How do I install the font usb to a ASUS P5PE-VM motherboard?
see mannual and find front panel usb connector on mainboard insert usb connector in it..
Apr 01, 2010 | ASUS P5PE-VM Motherboard
Mar 17, 2010 | ASUS P5PE-VM Motherboard
Is It required to connect Tower Front Panel I/O to Motherboard
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
May 23, 2009 | ASUS P4V8X-MX Motherboard
Front panel connection
Hi mubarakdream, please open your manual to page 1-6, motherboard layout. Find USB20_5 & USB20_6 page 1-14, at the bottom of the motherboard. You can plug your front USB onto these USB pins. (Careful, front & side case USB's break very easily). It only takes a slight bump to break.
Leave the motherboard jumper set to default for USBPWR_56, page 1-10.
If you need the Asus manual you can download it from this link;
If you need more information just post back into here.
Good luck mubarakdream!
Aug 26, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link.
Good Luck!
May 19, 2008 | ASUS P4P800SE Motherboard
Front usb hook ups
Check for seven pins under it it sould be marked USB 1 or USB 2 five pins in top row and four pins in bottom row
Nov 21, 2007 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
XION _ Solaris XON-407 ATX Mid-Tower Case Logo
156 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
Farokh Merek
Farokh Merek
JonSnell Electronic
JonSnell Electronic
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
