Question about Frigidaire Affinity ATF6000F Front Load Washer
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
  • Official Brand Answer
  • 4,342 Answers
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Posted on Jan 06, 2013
the dr
  • 447 Answers
SOURCE: Frigidair affinity front load washer
The water is turned off!!!!!!!!!!!!!!!!!
Posted on Jan 15, 2008
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on May 31, 2009
SOURCE: Frigidaire Affinity Front load washer,
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Posted on Aug 30, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Affinity frigidaire front load washer and
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Posted on Nov 13, 2010
What are the cubic feet for the affinity atf6000fs1
Hello Friend, this is Z. That's a great question!
I show that your Frigidaire Affinity washer (ATF6000FS1) has a total capacity of 3.5 cubic foot. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect.
Jun 12, 2014 | Frigidaire Affinity ATF6000F Front Load...
Door won't unlock on my ATF6000FS1
Hello Friend, this is Z. Thank you for allowing me to assist you!
I see that your Frigidaire washer (ATF6000FS1) door will not unlock. Sometimes, resetting power to your washer for about to 10 minutes does the trick. Once you turn on your washer, select a normal cycle and verify if the door will unlock. If not, your washer may possibly have a faulty door lock assembly, or a communication problem with the control board. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Jun 04, 2014 | Frigidaire Affinity ATF6000F Front Load...
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Fabric softener dispenser fills with water after every load
your overfilling it at start up ,,and its sphioning down only fill to metered line...and theres always alittle water in dispencer to keep it from sticking ,,but just a little..onthejob
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
195 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
