Question about Western Digital 2TB My Book Studio II Hard Drive
Can i use a power supply of 12v 2.5A instead of a 12v 2A (original), on my WD hdd???
The omne i have is the old one, with 2 FireWire 400 port, 1 USB 2.0 amd 1 eSata, and its capacity is 750 Gb (discontinued). The original power supply is not working and i would like to use anoder i have, but it has an output od 12v and 2.5A, instead 2A of the original.
  • 2,072 Answers
As long as the plug fits, it should run fine.
Posted on Jan 02, 2013
4 Suggested Answers
SOURCE: WD hd won't start up when turned on until you plug into usb
i cant put a solution for this but try the exact software for the disk which it came with this can help.Im also trying for the software
Posted on Nov 07, 2008
SOURCE: WD MyBook Premium not showing any capacity using Firewire
There seems to be a firewire port issue on the device. Why not leave it USB?
Posted on Jun 05, 2009
iklln6
  • 35 Answers
SOURCE: eSATA confusion.
There are not enough 'real world' benchmark reviews on the internet. The theoretical max of eSATA may be 3.0Gbits/sec (~375MBytes/sec) while USB 2.0 has 480MBits/sec (~60MBytes/sec) but you will never see this. You will be bottlenecked by the speed of your physical drive, bus speed, and other miscellaneous things that effect the speed of file transfer. I bought a drive with a USB 2.0 port, a Firewire 800 port, and an eSATA port in search of blazing fast file transfer. I found my USB 2.0 to cap out around 40MB/s, the Firewire ~70MB/s, and, to my surprise, eSATA at ~70MB/s also(!) I had my friend come over, who has a wicked awesome machine and a solid state drive, and we tested his. He had around 40MB/s on the USB 2.0, ~85MB/s on FW800, and ~90MB/s on eSATA. We concluded that we were seeing our computers cap out before the capabilities of the connections were achieved. We also decided that one of the large contributors to the issue was the spindle speed of the ext drive which we assume to be 5400rpm. Slow disk-spin equals slower file transfers. It would be interesting to test the connections from a solid state ext hard drive to my friend's solid state drive to see where the cap occurs when the spinning disk it taken out of the equation, but that is for another day.
You are not seeing incredibly fast speeds on eSATA because your computer can not handle speeds much faster than USB 2.0. Don't feel bad, my friend's $5000 macbook pro could not handle speeds much faster tan that, either. It is just how technology is, and how advertisers try to take your money. Next time a salesman comes up to you in best buy trying to trick you into buying an eSATA because it can hit a theoretical max of 3.0Gbs, punch him in the face, remind him that's gigaBITS per second, and push over a stack of books because our computers can't do that yet.
You are not stupid, my friend. I wondered the same thing when i first hooked up the eSATA. I went insane wanting the fastest file transfers because I was sick and tired of transferring slowly, but I feel better now knowing the max. Now i stick to less expensive firewire 800 because I wouldn't see the benefit of eSATA anyways (and I am also on a new macbook pro.)
Check out firewire, it'll tie with the fastest transfer your machine can handle, and it does not start and stop like USB so you get the gratification of watching a steady flowing progress bar.
If you desperately need faster transfers and have money to spend, here is how you do it:
Replace the drive in your machine with a solid state drive. Buy a 256 or 512GB solid state drive (large enough to enjoy, 512GB's are pretty expensive right now as they're a month old). Buy an enclosure from newegg.com for the size of drive you bought and an eSATA connection. Put it all together and there you go: you'll get much closer to that max. Be sure to hit me up with your results, I am VERY interested to see just how much of an increase in speed you have. Whether other components are to blame.
Posted on Jul 15, 2009
Hdd i/o firewire port won't work when connected with my hp probook laptop. do i have to install some drivers or firmware. when i use just hdd, things are just fine, evrything works fine. i need...
You cannot use the drive without external power, specially with the 4-pin firewire: there are some USB models that allow it (usually 2,5" drives), but you need 2 USB outlet oth the PC (one for the data and power, the second for power supply). About the compatibility you shouldn't have problems.
Aug 07, 2011 | Focus Enhancement FSHDD-1 (ASYF070701) 40...
I got a new computer with Windows 7 and my WD Book will not work. Can you assist? Earl
I assume your firewire port is not set up in W7
Can you move the old FiWi card form the old to the new computer? If not replacing the external drive to USB is the better option as firewire support is difficult therefore expensive to get.
sorry
rene
May 27, 2011 | Western Digital My Book WDG1C5000N 500 GB...
Need a replacement power supply, or at least need to know what input (volts and amps) the drive itself will take
Generic replacements for Seagate external drives are are pictured with a circular cross section plug with a yellow tip. They are rated at 12V 2A. They can be found on both eBay and Amazon.
If they look the same as your old supply, anything with that rating should be suitable.
There should be a sticker on the old unit with it's electrical characteristics, power ratings in and out.
Jan 31, 2011 | Seagate ST3500641CB-RK 500 GB FireWire 400...
My laptop won't recognize it
If the drive is not spinning, try another power supply, it requires a 12V/2A supply with tip positive. If it is spinning, try another cable or port. You might also try it on another computer.
Jan 21, 2011 | SimpleTech SimpleDrive 160 GB External USB...
Unusual Power Requirement
Should not be a problem, the theory here is Volts * Amps =Watts
5V * 2A = 10w
The alternative is to get a LM7505 ($1 or 2) from radioshack or any electronic supply and regulate the 12v down to 5v. its about 1/2 square IC chip.
Pardon my ASCII:
[_]
input 1.7V - 35V ________| | |_____ +5v (+/- 1%)
Pin 1 Pin 3
will accomodate 1 Amp (1.25 if heat sinked) for the CMOS version, slightly higher for the olde r(less effecient) version
The other pin is ground. OF course you will want to check the specs and pin assignment for the brand you buy, these are typical.
TechieJon
Apr 18, 2009 | Computers & Internet
Mount with Firewire 400 fails: WD MyBook Pro EII WDG2TP10000 1TB
hello. You may have erased some firmware drivers, or even have a bad connection on the unit. The easiest solution (if still under warranty) is to get the unit replaced. if not then you may have to make a visual inspection of the PCB at the iee1394 port (firewire/i-link) connection and make sure nothing is loose. if that fails, you may have to look up the particular company and request the firmware.
Nov 26, 2008 | Western Digital My Book Pro Edition II...
Oct 27, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Recover data on WD1600
ya pull hard drive plug it in diecrt into comp off stat port as slave drive go in safe mode drag drop info on to new hd if u can k
Oct 04, 2008 | Computers & Internet
Western Digital 2TB My Book Studio II Hard Drive Logo
95 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
