Question about Sub-Zero 700 Refrigerator Freezer Drawer-700 Sub-Zero
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
I have the 700 series. double unit, refig on top and four freezer drwers on botton
  • cindy DACEY Jan 03, 2013
    i cleaned condensors myself. still not cooling.
  • 45 Answers
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Posted on Oct 23, 2013
2 Suggested Answers
SOURCE: 2 yrs old, huge fridge
what brand? trying cleaning the condenser coil
Posted on Oct 22, 2010
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
On normal operation my freezer alarm will not stop bleeping.The only way to silence alarm is to switch to Fast Freeze ,however the compressor runs contually ,even after 24hrs and switching back to normal...
Have you cleaned the condenser grill and made sure you have plenty of air flow around the unit? It might also be time to take the food out and completely defrost your freezer! Since you do have an ice build up on your evaporator grill.
Jul 31, 2011 | Whirlpool Freezers
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Upright freezer quit cooling, compressor runs, interior fan runs. copper line from compressors, 1 is warm and 1 at room temp
Hi..
Try to check this
Good luck!!!
Regards
PCmania
Jul 08, 2009 | Frigidaire Freezers
Water leaking from ceiling of frig, no ice forming.
pat,this is tom.if your box temps are fine.then you have a blocked defrost drain.[if temps bad ,will condensate in fresh food because warm temps]couple ways one is to shut box down eight hours other is to remove the back frezer panel and clean out all that ice and clear drain.you can use blow dry to melt ice[watch water and electricty do mix at all,be carefil]once ice gone use weed eater line with nott in one end to push threw and come out ouher end and cleanin His name,tom
Jan 02, 2009 | Freezers
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sub-Zero 700 Refrigerator Freezer Drawer-700 Sub-Zero Logo
106 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Roderick Scott
Roderick Scott
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
