Question about Philips HSB3280/F7 Micro Hi-Fi Soundbar System Refurbished
Where can I get a replacement power supply for a Philips HSB3280/f7 sound bar?
I have a Philips sound bar modelHSB3280/F7 that requiers a 32V 35W power converter. I need to know where to get a after market one preferably!
SOURCE: Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Posted on May 06, 2010
SOURCE: Home Theater philips HTS3372D/F7 change for regio Free
Turn on the player
With the tray open press:
99990 on the remote
Region 0 will appear on the bottom left of the screen ]
from http://www.videohelp.com/dvdhacks
Posted on Aug 21, 2010
micromatikal
  • 2777 Answers
SOURCE: my philips dvd player hts3371d/f7 does not power
Well it's definitely either a failing power supply or a capacitor on a board somewhere that has gone bad. Trying to say which one remotely is like trying to pick which light-bulb failed on the front of a casino without looking at it. You are going to want to take apart the machine and inspect each cap one by one to inspect for damage. If you can't find anything then you will need to look into replacing the power supply.
Thanks
Tim
Posted on Oct 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: i need the code for
http://kbase.x10.com/wiki/Universal_Remote_Code_List
PHILIPS 398 408 423 PHILIPS 398 408 423
PHILIPS 398 408 423
Philips 398 408 423
Posted on Jan 25, 2011
SOURCE: I have a Philips Home
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Posted on Mar 23, 2011
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
Philips 46PFL5706/F7 46 LCD TV. When you turn it on you have power. The Philips logo appears for a second then goes away. Screen is black after that.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 30, 2015 | Philips 46PFL5706 - 46" LCD TV -...
No power coming for Philips LCD tv
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 24, 2014 | Philips Consumer Electronics Philips 32"...
How to fix 40pfl4908/f7 will not turn on
My philips tv no 40pfl4908/f7 has a white flashing light and the tv does not turn on
Mar 15, 2014 | Philips 40PFL4908/F7 - 40 LED 1080p HDTV...
Size of fuse for a power supply board on a Philips 42" tv model number42pFL6704D/F7
The amp rating of the fuse is written on the metal cap on the fuse.
Dec 21, 2012 | Philips 60PP9200D Television
I need the cox remote code for philips sound bar css 2123/f7
I too need this code, if such a code exists. I have found several that control the mute and volume, but none so far control power.
Jul 19, 2012 | Televison & Video
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Philips HSB3280/F7 Micro Hi-Fi Soundbar System Refurbished Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
