Question about Air Intake & Fuel Delivery for Suzuki Aerio
My car 2003 suzuki aerio Sedan some time Engine turn off
Hi My car 2003 suzuki aerio have Problem since 30 days the car engine going turn off. i already change Spark Plug and also i change Fuel Filter. but still i have problem.
    Champion:
    Scholar:
  • 227 Answers
You might have an intermittent sensor problem. if you can recreate the problem easily head to a repair shop and show them how to get it to do it, and let them diagnose it.
These problems can take hours to figure out, even for Master Technicians like me as you not only have to get it to happen, you have to see it happen.
Posted on Nov 01, 2013
2 Suggested Answers
Android606
  • 24 Answers
SOURCE: We have a 2003 Suzuki
I'm not an expert with the Suzuki, but I have had lots of experience with transmissions. Chances are, one of your shift solenoids is bad and needs to be replaced. There's also a much smaller chance that the wire going to the solenoid has been pinched or broken.
Ultimately, the car will have to be connected to a professional-quality scantool and driven to confirm it. Then, the solenoids will have to be removed and tested. They are always either located on the valve body in the transmission pan, or they are attached to the top or side of the transmission as a "solenoid pack", where all of the solenoids are replaced as a unit.
Step one for you is just to make absolutely sure the fluid level is good and the fluid isn't burned or contaminated. It should be nice, clear, and pink. If it smells bad and looks more reddish brown than pink, or it's shiny with metal flakes in it, then something else is wrong.
Posted on Dec 31, 2010
Engine Oil capacity for Suzuki 2003 Aerio
no engine stated or countryl
open glove box,take out that OPR guide
read, its there.
or go to shop
the drain it
and fill it to the dip stick full mark , whatever. it takes
or measure what came out? (6th grade,tactics?)
Feb 07, 2017 | 2003 Suzuki Aerio
What kind of oil does my 03 aerio take
Suzuki Aerio with a 4 cylinder, 2.0 engine. The manual "Highly Recommends" a 5W-30 , but a 10W-30 is also suitable.
Feb 05, 2015 | 2003 Suzuki Aerio
Change the timming belt
is this a question? and no engine option stated, impossible.... that.
who can?
how can I DIY, do it?
what parts are best. who sells them. or? or ?
what are the 50 steps>>>>>'/???
why not RTM , read the manual first then ask questions about the 50 steps that are no clear.
this works best and the manual is here.
the engine ?????????
1.3 L I4; 1.5 L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L Diesel I4
or read the manual?
https://suzukipitstopplus.com/Products/1178-2003-aerio-service-manual.aspx
all cars have a FSM and anyone can read them, if motivated.
$4 day pass, cheap. too.
Aug 18, 2014 | 2003 Suzuki Aerio
"service engine" light is on after battery went dead and the jumped start my 2003 Suzuki Aerio sedan
scan it. (plug in any scan tool and read it (USA answer.)
use a scan tool, also there are some things that need do be relearn
and all this is covered in the FSM or the operators guide(briefs)
idle relearn
tranny relearn. etc,,,,
or at alldata.com. might be there, too,
scan it, and see what codes you get.
i have no idea what engine option you have or transmission..
i bet you lost the radio code too, and never backed it up.
Nov 29, 2013 | 2003 Suzuki Aerio
Why my car 2003 suzuki aerio Sedan turn off when im driving
ill add guesses. stalls. does it restart, easy????
1: lost electrical power to the EFI system.
2: lost fuel pressure
3: lost spark , lost fuel injections.
4: egr leaks, (clean and get it to close, it must close at idle or the engine will stall. 50k mile service point in the manual.
Apr 14, 2013 | 2003 Suzuki Aerio
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    How turning off service engine soon ligth for a suzuki aerio sx 2003
    usually if you turn the ignition key on and off 3 times it will reset it but dont start it just turn key on off on off on off.
    Apr 09, 2011 | 2003 Suzuki Aerio
    Suzuki aerio engine 2.0L have timming belt or chain?
    TIMING BELT SHOULD BE 60,000 MILE CHANGE
    May 08, 2009 | 2003 Suzuki Aerio
    Air Intake & Fuel Delivery for Suzuki Aerio Logo
    96 people viewed this question
    Top Suzuki Vehicle Parts & Accessories Experts
    gbob59
    George Agios
    George Agios
    Are you a Suzuki Vehicle Part and Accessory Expert? Answer questions, earn points and help others
