Question about Exercise & Fitness
Pedal tention too tight - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
Step 1:
please proceed with this step . Happy new year and God bless you
Lubrication
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright
Step 2:
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 3:
Link Arms
Unplug the power cord. Identify the pivot points where the lower handlebars and the footpad link arms connect at each side of the machine. Use a screwdriver to remove the inside and outside elbow covers at each connection. This will expose the pivots.
Put a box wrench on the lock nut at the inside of one pivot and loosen the bolt with an Allen wrench. Remove the bolt and check the assembly for nylon spacers or a bearing. If no spacer is found, proceed to the next step. Replace the nylon spacers, reassemble the connection and reattach the elbow covers. Repeat this at the opposite side of the machine.
Have an assistant hold a deep socket against the inside face of the pivot hub. Make sure the socket is large enough to allow the bearing to pop out. Insert the point of a flat screwdriver into the outside of the hub until it contacts the bearing. Tap the handle of the screwdriver with a hammer to remove the bearing. Repeat this to remove the bearing on the opposite side.
Hold each bearing next to one ear and turn the inner race with your finger. If you hear grinding noises or the bearing is rough, it must be replaced. Lubricate the bearing with lithium grease and a grease gun. Replace the bearing into the hub. Reattach the lower handlebars and footpad link arms and put the elbow covers on.
Posted on Jan 01, 2013
Emergency brake stuck to the floor
if your mechanical minded you can release it with a flat blade screw driver but it will be tight ,you need to release the tention by pushing hard on the pedal ( or use 2 people) and you will see how the ratchet locks the pedal pry up on it while you slowly lift the pedal up .
Mar 03, 2015 | Cars & Trucks
Chevy Lumina 1994 3.1 V6
Take a ratchet u will see small square box that the rachet will fit.as u tight in it should move The tentioner should move one way or other u will see then slide off .make sure u remember the way belt is on if u don't have diagram
Jan 05, 2015 | Cars & Trucks
How do you move tensioner pulley to install new serpentine delt on a 2002 Audi 3.0 motor
If your tentioner pulley is to tight the next time you go to tention the belt it can brake the pulley bracket remember it is aluminum
Jan 09, 2014 | 2002 Audi allroad
Yardman LT1238 stuck in gear
All the clutch does is to remove belt tention by moving an idler pulley, so with the machine stopped, depress the clutch pedal and watch the idler pulley moving away from the belt, and the belt should become slack, if not check all the linkages, if the belt remains tight and the idler has moved away, then replace the belt, it is very important to have the correct belt lenght,
Apr 16, 2012 | Yard Man Garden
My thread keeps breaking. I got this machine
Thred breaking is one of the following: tention to tight, wrong thred, wrong needles - use jersey baal point 80/12 needles for all material and thred, bobbin tention too tight. wcbotha@yahoo.com
May 10, 2010 | Sewing Machines
Serpentine belt on 96 saturn sc loose what could it be
Hello there:
Normally a serpentine belt will stay on tight untill it begins to strech out after it streches out to far the tention idler pulley cannot keep the belt tension tight any longer thus resulting in a belt either coming off or other things happening So what i would do is to first remove the serpentine belt and ensure that the tention idler pulley is working good make sure it does not just move freely than get a new belt and install now you should be ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | 1993 Saturn SC1
No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Dec 07, 2009 | Cycling
When making a slow tight turn, the front wheels lock up and push.
This is a common problem on 4x4 trucks and jeeps, it is cause by stress building up on the axels, An easy way to relieve the stress is to drive in reverse for a few yards, this relieves the tention that builds up on 4x4s. I know it sounds crazy stress and tention?? it has to do with the ratio on turning radius, the outside wheel has to travel farther than the inside wheel and this causes stress and tention on the axel/front end.also try and not turn so sharp.you will notice that goes away if you dont turn as sharp...
Oct 23, 2009 | 1983 Dodge Pickup
I am having stalling problems with my engine
if this is a 97 you have just one belt ,this is kept tight by a tention pully ,as far as the ideling it sounds like the throttel cabel has come loose this is just a guess but this can bee check fairly simply .i would suggest geting a manuel from a local part store about $15.00 hope this helps
Aug 04, 2009 | 1997 Dodge Ram 1500 Club Cab
How to change pulley on curcumtine belt tentioner???
you will have to remove theengine mount in front of the timing cover then jack the engine up with a floor jack be careful not to damage the oil pan i usually put a piece of two by four between the jack and oil oan to keep from crushing it just watch and use your judgement when the engine is high enough.this will give you enough room to replace the tensioner it will still be a tight fit but trust me it will come out
Jan 12, 2009 | 1999 Honda Accord
Exercise & Fitness Logo
64 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
