Question about Niko OTP-2011R 20 in. LCD EDTV
How to set up tv from menu selections...
Can't figure out how to use the menu to make the selections for picture/sound/set-up, etc. need step-by-step directions.
  • abwerth Jan 21, 2009
    What areas do I adjust, picture set-up? Skip channels?
  • osumom2003 Apr 03, 2009
    i can not set up that as well but they also lost my remote can i do it froim the tv?
    Sergeant:
  • 227 Answers
When on menu push the up down arrows on the remote to select what options you want.
Posted on Jan 18, 2009
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Akai tv picture no sound
If picture is OK, sound should be there. Check the settings to sound first, ie, 'system' 'mute' etc, by entering the sound menu. If an improper system is selected, the sound will be either absent or distorted. If all the other settings are OK, and still there is no sound, you have to check the audio output section circuit, speakers etc?
Jul 19, 2013 | Televison & Video
Tv picture is fading
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 27, 2013 | Philips Televison & Video
81@hI have a LA32B550KIF LCD TV by Samsung. Just recently the picture has gone but we still have sound. Is there a step by step manual that I can follow online to reset the settings? I have currently...
Hello destinee81, let me help you.
I often see things like that, mostly occurs because the problem panel.
To ensure it, first turn tv on than wait a minute until you hear a sound from a channel tv.
After you hear a sound and still no pict, knock gently the panel with your hand ( not too hard but not too soft). If you see a flashing light (on area you knocked) , that mean back light panel is OK. Open rear cover , there are 2 boards (Power board and Main board) and 2 board attached on panel (inverter and T-con) , "beware with high voltage on power an inverter board". Check connection on t-con and main board, clean it with brush to remove dusts on it. if still make no changes , replace the t-con board.
Second, repeat first step above. If there are no flashing light on knocking area,. that problem from inverter board. Replace it. If any problem and questions, please let me know.
I hope that will help you. Thanks.
Mar 23, 2011 | Televison & Video
We need to figure out how to get it off of the 3d setting we just recieved this tv from a friend of ours and we are trying to figure out how to view it without the 3d our tv is a mitsubishi big screen...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 29, 2011 | Mitsubishi WS-65907 65" Rear Projection...
JVC I'Art Pro the color's don't line up in the corners its like the red has a concave shape so there is a perfect picture in the middle but the corners are off, anyway what i need to know is how i can...
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 23, 2011 | JVC AV-56WP30 56" Rear Projection...
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
Hello
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Blue Screen w/ sound
I've tried many different things to isolate the problem, the only solution is to manually reset it to factory settings via menu button. If something goes wrong, like the menu button freezes turn off the monitor *Or unplug it, and retry to reset factory settings. Unfortunately you have to do this almost every single time you turn off/on the television.
Oct 28, 2007 | Polaroid LCD-2050 20 in. Television
Niko OTP-2011R 20 in. LCD EDTV Logo
106 people viewed this question
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
