Question about HP Photosmart Premium C309A All-In-One Printer
Clean under glass - HP Photosmart Premium C309A All-In-One Printer
  • riotti
    riotti Jan 02, 2013
    I need to clean under the flatbed glass. How do I remove it to clean it?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
For Scanning.
Posted on Jan 02, 2013
  • riotti
    riotti Jan 02, 2013
    What do you mean "For Scanning"? I need instructions to clean under the flatbed glass. How do I remove it to clean it?
5 yrs.old. After last self-clean, yellowish staining on front panel but on porcelain UNDER the glass.
you can separate the door to clean but it is not an east task . this is one reason I will not let wife use the self clean feature .
Aug 11, 2015 | Kenmore Kitchen Ranges
How do you clean under the glass of the Canoscan 4200f
I have a Canon 4200F, and you can refer to this one I have already answered:
http://www.fixya.com/support/t19119519-clean_inside_glass
Have a good day
GB
Oct 09, 2012 | Canon CanoScan 4200F Flatbed Scanner
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
When I try to copy a letter or anything, a black line shows up down the center of the printed copy. How do I remove this?
look at the scanner glass. It probably has some dust specs on it, clean it . Also clean the small glass toward the left of the scanner glass. If the dust specs are under the small glass, you can carefully remove the glass and clean it.
Jun 28, 2011 | HP Photosmart Premium C309A All-In-One...
My sharp AR337 always showing E7-11, when i clean
clean white surface under the glass.then push scale on the glass and make copy.few push glass holder metals near copy lamp.
May 14, 2010 | Office Equipment & Supplies
The glass top on one burner has discolored under the glass as if it is burned under the glass. nothing will clean it. what do I do to get the black out
if under glass it will have to be removed to clean/ it might not clean. . the replacement is only other ans . mm
Dec 06, 2009 | Refrigerators
Need to clean the under side of the glass. Need
I found a service manual on-line that showed the method for removing the glass on the scanner.
Nov 16, 2009 | HP Office Equipment & Supplies
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Failure to print properly
Is the machine a digital machine? If so there is a slight chance that the reason for the problem is that the mirrors are dirty under the copy glass. Remove glass and using glass cleaner on a soft cloth clean mirrors. Do not remove mirrors........
Clean copy glass and replace. If problem still there poss developer change or drum unit but most common is optic section. Also clean a **** glass in the machine. Open the door and you will notice a glass rod sticking out just above the drum unit. Remove clean and reinstall.
Hope this helps
Thanks Jason
Aug 16, 2008 | Canon Office Equipment & Supplies
HP Photosmart Premium C309A  All-In-One Printer Logo
Seeker5211
Seeker5211
