Question about Kenmore 61652 Microwave Oven
Microwave suddenly stopped working
Whenever I press "Popcorn", my microwave starts, but stops after about two seconds, and F3H appears in the window. I tried to pop the popcorn manually, and it still didn't work, as if the microwave is running, but not heating anything. It isn't even five years old, and I don't use it that often.
  • 1 more comment
  • Shari Stark Jun 26, 2007
    Thank you, MicrowaveSvc, for your response. I contacted Sears, and they said it was $65 for a repairman to come to my home. The magnetron is under a five year warranty, giving me a couple of more months. I'm wondering if I should just have it replaced now vs. later, and having to pay for it. What is the price of a magnetron?
    I forgot to mention that Sears told me to unplug my microwave and plug it back in. It worked, and so far, I haven't had any problems.
  • Anonymous Mar 24, 2014
    Light turn on, it revolves but doesn't warm anything , last time I made some popcorn
  • Kenmore Master
  • 9,156 Answers
Code F3 indicates an open / defective thermistor / temperature sensor. The first suspects when a microwave is not heating would be the door switches, bad connections on the magnetron terminal or bad connections on the control board. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 26, 2007
  • William Miller
    William Miller Jul 03, 2007
    You can enter your full model number and find the price here:http://www3.sears.com
SOURCE:
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Emerson MW8119SBM microwave. Use popcorn button.
Try clearing the microwave before pressing the popcorn button again.
Feb 21, 2010 | Microwave Ovens
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Nov 26, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
424 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
