Question about Sony MDS-JE520 Mini Disc Player
I have 2 model # mds je510 & 2 model mxd-d3 code c14 error
I tryed everything possible some disc are still working i have lost about 6 disc could it be that one of them is deleting my music they played find before could it have to do with moving my songs around on disc to many times or one unit deleting its info then stopping that disc from not be able to play on other machines other thought replacing track # 1 with other song could some one please help me on facebook carole devos-aubin
  • Sony Master
  • 1,267 Answers
Mini disc units are funny- when you get one that works then you are good to go. But when you have a malfunction you have to take very careful steps as when discs get stuck or the system crashes- the wrong action will damage the TOC (Table of Contents) and then the disc can still have the music on it but the unit doesn't know where it is. I have seen many people in radio studios do the wrong thing and the data on the disc is lost. It is best to do straightforward type operation on these units and then once a problem is observed- best to have it serviced right away- hoping it goes away usually results in a broken plastic piece and a unrepairable deck. I know radio stations that have piles of those unit in the closet. The solution to mechanical issues is lubrication and a current limit resistor on the motor circuit.
Posted on Jan 29, 2013
3 Suggested Answers
HW_Dude
  • 87 Answers
SOURCE: Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Posted on Mar 18, 2009
  • 3 Answers
SOURCE: how do I play only one track at a time instead of
HI THERE,YOU NEED TO RECORD THE SONGS ON TO THE DISK ONE AT A TIME,PAUSE THEN RECORD THE NEXT SONG.I AM AN ENTERTAINER AS WELL AND HAVE USED MINI DISK PLAYERS FOR 14 YEARS...HOPE THIS HELPS,CHEERS MARILYN 'ROJENE'.
Posted on Apr 22, 2011
Why does the display flash with the word Standby when I switch on?
Some of the decks when first plugged in or powering up need time to get started. I'd wait then press the on button and see if it then turns on.
I get this message on my JA50ES when it has been unplugged or the power went off. It will say standby then you have to push the on button and then it works. I also have this situation with an older Sony Blue Ray Player. My newer Blu Ray comes on fast the older one has a similar situation...
Other possibilities are 510 is just wearing out... The 510 was great but it is an older model. Old units are not worth fixing should this be the case go for a 600 MD Deck (later model) or consider one of the ES Decks. (higher end).
May 14, 2014 | Sony Minidisc Deck Mds-je510 Recorder
Not recording anymore
After you press the 'record' button the Minidisc unit is still in "pause mode" - you can hear the music and see the meters move, but notice that the time isn't moving until you press "Play" - then it will start recording. Is the time changing when you go to play it back? You might have left the MD in 'pause' perhaps?
Jan 30, 2014 | Sony Minidisc Mini Disc Remote Control...
Toc error c14
Player cannot read the table of contents on your disc for some reason.
Nov 10, 2013 | Sony MDS-JE330 Mini Disc Player
Read error c14
Deck cannot read your disc...
Sep 28, 2013 | Sony MDS-JE480 Mini Disc Player
Toc error c14
Deck cannot read the disc for some reason try another disc.
Aug 26, 2013 | Sony MDS-JE330 Mini Disc Player
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
Can i transfer music from MP3 player to minidisc?????
USing the sonicstage software you should ba able to do it. If you can get the software working
Feb 24, 2009 | Sony MDS-JE480 Mini Disc Player
Need a recording head for Sony MDS-JE510 minidisc deck
Please confirm the "Over Write Head" marked in below picture, if this is the case then its part number is as follows...
1-500-396-11 HEAD, OVER WRITE
and available in Part Store on approx $38
Good luck.
Dec 15, 2008 | Sony MDS-JE480 Mini Disc Player
MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
Jan 12, 2008 | Sony MDS-JE480 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
138 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
