Question about Mitsubishi VS-60703 60" Rear Projection Television
Tv goes to another channel on its own
Every time I turn it on it goes to another channel and I have to enter 3 so I can get a picture.
    Sergeant:
  • 227 Answers
Sounds like channel 3 is not locked in. Go to menu and select add/delet channels And add 03.
Posted on Jan 18, 2009
I have any rca tv remote will no go up after channel 9
Two things to suggest: first check in main menu set is in correct band---air or cable depending on signal source used.
Second: with a remote direct enter a channel known to be p resent like 15, enter and see if set goes there---if it goes there but no signal or picture you may have a bad tuner.
If it goes there and you have a picture then in the menu MANUALLY add it to the up/down channel memory.
May 15, 2012 | Televison & Video
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Can't get tv to change past 9 with remote
You probley need to go into the menue and manually enter or add the channels to the scan program of the tv. The numbers are some times pin when they arenot in scan and turn green or yellow when they are in the scan pattern.
Mar 01, 2009 | Panasonic Televison & Video
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Continuous Channel Searching & Power Button Issues
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
Mar 20, 2008 | Audiovox FPE1078 7.8 in. TV/DVD Combo
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
Televison & Video Logo
259 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
