My Vizio E470VL turns on for 3 seconds showing the Vizio logo, then turns off. I think I accidentally locked the input by trying to change the video source. Is there any way to fix this?
I tried unplugging, then holding the power button for 60 sec., then turning it on. I also tried unplugging all chords, and replugging to reboot, but still no luck.
  • 8,617 Answers
The main board has an issue its usually a eprom but thats hard to replace without alot of soldering skill. However you can replace the main board they are available from www.tvrepairworld.com
Posted on Jan 01, 2013
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
  • 4 Answers
SOURCE: It won't turn on
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Posted on Dec 28, 2009
  • 9 Answers
SOURCE: television will not turn after a 10 minute power outage
Depending on what made the power outage, your power supply might have got fried. It might be as simple as a few capacitors blowing or a little more serious. I would suggest taking it to a repair shop. A power supply replacement will run you about 200-250. If its just a few capacitors, should be around 100.
Posted on Mar 31, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Westinghouse W3223 TV which has decided
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 25, 2010
Testimonial: "Thanks very much! That seems to have worked."
ladywinn
  • 5138 Answers
SOURCE: the audio and picture on my vizio vt470m are
You could have Bad Capacitors on the Power supply board they will be vented or swollow on Top
1000uf 16v 2200uf 10v 3300uf 10v.
PTS they rebuilt boards 1-800-844-7871
Posted on May 31, 2011
Testimonial: "Thank you very much!"
Vizio model M320SR has black screen but has sound. V logo appears when tv is first turned on then goes away.
If there is no video but you have audio or you have intermittent video:
  1. Press and hold the mute button on the VIZIO remote for 3 to 5 seconds. Some VIZIO TV's have a "Mute Screen" feature that turns the screen off if you are streaming an audio application (Pandora, Spotify, etc) and don't want the screen on. To activate/deactivate this feature, hold the mute button for 3-5 seconds.
  2. Turn the TV off and unplug it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
  3. Check the connections between the TV and device. Ensure the cord is connected securely to the TV and the source device.
  4. Try a second device. (Example: If the issue happens on a Cable/Satellite box, try using a DVD player or gaming system to see if the issue occurs there.)
    1. If the issue occurs on multiple devices there is an issue with your TV. Please contact Support by Clicking Contact at the bottom of the page or give us a call Monday - Friday from 7am - 11pm Central Time or Sat. & Sun. from 9am to 6pm Central Time at 855-833-3221.
    2. If the issue only occurs on one device the issue is not with the TV but with the device or the cables used to connect it to the TV.
Jan 26, 2017 | Vizio Televison & Video
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Can you help me fix my TV?
because television circuit boards are available off the internet, people think they can repair their own televisions. The course to become a television engineer is 2 years full time. Time and time again we see people who have spent hundreds of dollars changing one board after another and still can't get the set to work. My advice is look at Google and find a television repair engineer in your town, or take it back to the shop where you bought it if they take on repairs.
Try this though
How to fix a Vizio TV?
Power cycling can solve a lot of odd problems with Vizio TVs. First disconnect the TV's power cord from the power outlet and leave it unplugged. Then press and hold the power button on the TV for 10 seconds. After you have held the button for 10 seconds, let go then try to power the TV on.
Google
visio television repair
They are a budget set anyway. Check out these links for common Visio problems and fixes.
visio television repair Google Search
Aug 15, 2017 | Vizio Televison & Video
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
Vizio E470VL with no sound after main board replacement
No, your video and audio processing should take place on the same main board.
Feb 12, 2013 | Vizio E470VL 47 in. HD-Ready LCD TV
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
