Replacing a Seco 24 VAC Heat pump thermostat TA2000
My old mercury thermostat has W2-white, O-orange, X-blue, R-red, Y-yellow, and G-green wires. My new thermostat has E, AUX, Y, G, O, L, R, B, and C. I think W2 is AUX, Y-Y, G-G, O-O, R-R, but I don't know where my X-blue wire goes. Can anyone help me?
  • Vicki LaVoilette Jan 03, 2013
    The new thermostat is a Honeywell RTH3100C...Non Programmable. I do have a heat pump.
    I'm thinking W2 = Aux, Y = Y, G = G, O = O, L is Not used, R = R, B is Not used, and C is optional if I use a battery. Do I jumper E to AUX?
4 Suggested Answers
  • 96 Answers
SOURCE: Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Posted on Feb 01, 2009
jeffbvegas1
  • 520 Answers
SOURCE: wireing a honeywell thermostat
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Posted on Jul 24, 2009
heatman101
  • 43501 Answers
SOURCE: No Auxiliaty heat with new thermostat
The Vision Pro is a great t-stat and I have installed many of them with great results. I am wondering though if it is set up correctly. Did you go in and make sure that it is set for heat pump and for 2 stage heating? Look on the instructions how to get into the advance installer options. Go through that meanu and make sure that everything ig set correctly for your type of heating system and that it is set for 2 stage heating. From what you have here and I can tell the wiring should be okay that is why I think that it is in the t-stat programming.
Posted on Nov 16, 2009
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
Replacing a TA2000 WITH RTH6500fw
the terminals where the wires go should be marked with letters put them back on the new t-stat matching the letters c is common on heatpump white and yellow should be jumpered togeather and if your new stat has rc and rh they should be jumpered and on heatpump there should be either an o or b hooked up but not both this is for shifting heat or cool
normaly red to red 24v hot...green is indoor fan....yellow is compressor and or white also....blue is reversing valve energize for heat orange is energize for cooling ...and black or brown is common which is neutral or ground for the 24volts
Mar 14, 2014 | Heating & Cooling
Installing a honeywell thermostat with a goodman cpke24-1ab heat pump
r is red c is blue w is white y is yellow g is green o is orange w2 is w2 is also white e is brown but some installers dont follow that pattern so maybe this helps red is 24voltpositive c is 24voltnegative yellow is compressor white or w2 is heat brown is emergency heat orange is reversing valve green is fan
Mar 31, 2013 | Goodman CKL30AR30 Air Conditioner
Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Apr 02, 2010 | Honeywell Electronic Programmable...
Old wiring looks like this yellow =y1 green =G white=w2 orange =O blue=C red=R installing a Honeywell RTH7600 where does the orange wire go we have a heatpump.L
If you have a heat pump, the thermostat that will operate it most generally will have an "O' terminal for the orange wire, this is the circuit that energizes the reversing valve on the heat pump, be sure that the stat says heat pump on the box. hope this helps
Nov 02, 2009 | Honeywell Electronic Programmable...
Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
Oct 20, 2009 | GE Zoneline AZ55H09D Air Conditioner
Installing programable thermostat it has 5 wire points, i have 7 wires off the unit which ones do i use
For heat pumps........
R = Red wire (hot24v)
G = Green wire (blower motor)
Y = Yellow wire (AC condensor)
C = blue wire (common)
O = Orange wire (reversing valve)
W1 or W2 = White wire (emergency heat)
For gas furnace
W1 = white (gas furnace)
R = red
G = green
Y = yellow
C = blue
Sep 22, 2009 | Heating & Cooling
Heating & Cooling Logo
573 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
