Question about Generac Guardian Electrical Supplies
I have a generac guardian plus generator #43903, i haven't heard it self test for awhile, opened the lid and the redlight next toover crank is on, how do i reset this and is the circuit breaker bu
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
  • 14 Answers
SOURCE: Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
Posted on Oct 01, 2009
Testimonial: "This is good information in the event that the low oil switch is part of the problem."
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Why does it crank and almost start on 1st try?
    Generac Generator Troubleshooting - YouTube
    ? 1:39
    https://www.youtube.com/watch?v=AKN2dc59cxY
    Dec 20, 2013 - Uploaded by Appliance Princess
    I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
    Generac Power Systems - ConsumerAffairs.com
    www.consumeraffairs.com > Homeowners > Utilities
    Rating: 1.3 - ‎26 votes
    Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
    Generac standby generator - Propane - wont start?? - DoItYourself ...
    www.doityourself.com/.../487838-generac-standby-generator-propane-w...
    Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
    141 GENERAC complaints and reviews @ P'ed Consumer
    Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
    How to change the fuel filter on guardian quietpact rv generator
    Dec 05, 2015 | Generac Electrical Supplies
    My Generac HSB 17W AC Model 0055040 Generator will crank but won't catch and run. Propane tanks are full and have never been empty. What can I do?
    Check for igntition at the plugs, check power is going to fuel solenoid. If power is on solenoid check LP pressures and make sure it is opening. Be carefull LPV is dangerous any spark can cause a fire. Check to make sure the throttle is opening during cranking, if it isn't it's a control issue
    Oct 12, 2013 | Generac Guardian Electrical Supplies
    Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
    Leigh,
    See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
    Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
    My rpm sens light is flashing on my anunciator panel generator will not crank
    you may have to reset it, its probably shut its self down, on safeties. and wont restart till you clear it..
    Aug 13, 2011 | Generac Guardian RTSE200A3 200 Amp...
    I hava a 20kw NG guardian gen. When it does its weekly 12 min. test run it most always runs rough and seems to be choaking itself to death.
    I have a 400kw unit that does the same thing, I found the regulator needed to be execersized. when the unit starts I shut the isolation valve ahead of the regulator and then when it almost shuts of the gen. i open the valve back up and then everything is ok, hopefully after awhile it will work right.
    Jun 28, 2009 | Generac Guardian Quietsource 25,000 Watt...
    Electrical Supplies Logo
    60 people viewed this question
    Top Generac Guardian Electrical Supplies Experts
    jdthefixer
    epangan29
    ken skalski
    Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
