Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Have a whirlpool side by side
Freezer side has gotten warm. Temperature was on B. No food appears to be blocking the vent. Refrig is 10 years old. Refrigerator side seems to be working fine. Any suggestions
  • dcrupi Jan 18, 2009
    Tghe fan does seem to be working. I can feel cool air coming out from it. There is ice in the ice making tray. Not sure yet if it has stopped making ice. There is dripping occurring from the bottom of the ice tray due to the warmer air.
  • Mathew F
    Mathew F May 11, 2010
    Is the fan working on the freezer side?
    Does it have any ice on the freezer side?
  • 700 Answers
Have you tried t clean the coil underneith the refroigerator? Take the front lower panel off and th eback off. use a loge handle brush and a shop vac and clean the coil thats underneith the unit.
Posted on Jan 21, 2009
Why is freezer way too cold and fridge too warm when the temp display actually states the preferred temp?
Check the fan in the freezer section, its probably not working or turning too slow. Also check the fresh food cold adjustment its really just a door that gets adjusted, but it could be blocked with food, stuck or broken.
Sep 01, 2014 | Refrigerators
Evaporator fan is running but refrigerator side still not cool
Possibly blocked vent between fridge and freezer. could be ice or frozen food that has gotten in vent, blocking air flow. Also you say the fan is running but can you SEE IT? I have had occasion where the MOTOR is running but the fan blade is loose on the motor shaft. especially top freezer models.
Feb 01, 2014 | Whirlpool Refrigerators
I have a Kenmore side by side refrig. and the freezer side keeps getting full of frost, and the refrig. side is barely cold, and keeps spoiling food. I've had a tech come out and check things out and...
Either your defrost element or timer is bad or your fridge is low on freon. Frost is a sign of outside air getting in but it can also be a sign of the defrost heating element not kicking in and the defrost timer turns it on for a few minutes each day and a defrost limit keeps it from getting two warm during the defrost cycle. good luck hope this helps
Aug 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
110 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
