Sceen is on, sound is on,but imegen is not, this is a phillips 47' lcd tv can someone help me is like 4 years old
  • 8,617 Answers
That could be a Tcon or a main board issue. Can you post a picture of the screen? also will need the model number. Please respond to this same post for further assistance.
Posted on Jan 01, 2013
  • 5 Answers
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Posted on Jun 03, 2008
pwrblnc
  • 4 Answers
SOURCE: TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Posted on Feb 28, 2009
  • 71 Answers
SOURCE: my sanyo lcd tv has sound but no picture
contact the customer care
Posted on Mar 05, 2009
SOURCE: LG 50PX4DR plasma tv
I had the same exact problem as posted above. My 50" LG plasma was out of warranty for 1 year! I called the LG executive call center, and they were very helpful. They offered to pay for the parts and labor. They recommended a few local repair shops, and they set everything up for me. The tech came out within 4 days with one part. The tech had to come out one more time the following week, since more parts were needed for the repair. The Y sustain board, along with 2 adjacent parts that are required to be replaced as a set, and the power supply had to be replaced (parts alone cost just over $900). TV is like new again; I'm very happy with how LG handled it, and made what could have been a bad experience a good one.
Posted on Apr 30, 2009
alpug
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
Phillips 409fl7505d/f7
I once had a problem with a Phillips tv.It was less than one year old and one day ,all of a suddenm a black screen came up.I elarned it was called the "black screen of death" and that other people had gone through the same thing.Someone online had actually written to Phillips and they had gotten a new TV form them,so I tried the same thing and amazingly,Phillips gave us a new TV and came and took the old one.The enw worked fine. So you may have a lemon on your hands.Unfortunately, I do not have the letter I sent to them but the replacement they sent me was part of their "Rapid Replacement" program.This wa sin 2008 so I'm not sure if they still ahve it but it may be worth a try.
Apr 09, 2013 | Philips 40PFL3705D 40 in LCD TV
Panasonic 32" LCD TV showing almost Black pictures
If a 4 year old 32 inch set likely cheaper to replace than repair it assuming parts are even still available.
Aug 25, 2012 | Panasonic Viera TX-32LX77 LCD TV
I bought a phillips 32 flat screen 5month ago,and it has gone wrong,it works for 20 mins then the picture goes off the sound stays on
Tv is less than a year old call Phillips for warrenty repair.This tv have a 1 or 2 long boards,call the LCD inverter boards,it have problems,about to died.These 1 or 2 long LCD inverter boards are to help the LCD screen to have a backlight to produced a picture.That why u have dead pictures,but still have sound.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Sep 20, 2010 | Philips Televison & Video
Our Phillips flatscreen, is only 3 years old, but now the top 4" is reflecting upside down.Any thoughts
This issue sounds like the lcd contoller. You would have to carefully remove the boards and towards the top of the tv there will be a plate about 6"x4" the lcd controller is under that. Becarefull with the plug that plugs into the buttom of the lcd controller, wires in that plug are really small. Good Luck
Dec 16, 2009 | Philips Televison & Video
Phillips Model 60PP9100D/37
Its a common problem on this model. Most likely the HVG. Goto www.TvRepairKits.com for a kit with instructions.
Apr 19, 2009 | Philips 60PP9200D Television
LG 37LG3000 repacement or screen repair
Unfortunately, the LCD panel will have to be replaced. The LCD panel along with the labor could cost close to $1000 to replace. In most cases it is cheaper to just replace the TV. The manufacturers warranty will not cover damage usually. Sorry.. Wish I had a better answer
Dec 20, 2008 | LG 37LC7D 37 in. LCD HDTV
Lcd shadow
you need to call acer you have a bad lcd sceen. i juct di one the sceen was fault.
Mar 30, 2008 | Televison & Video
Mitsubishi 62" projection LCD
dirt internal to the tv. suggest taking the screen off and removing the small rectangular panel in the middle and spraying off LCD panels located under metal fins. this should fix distortion.......for now.
Oct 31, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
