Question about Juki TL-98Q
Needle Thread breaking after about 30 seconds of quilting
I am currently using a Juki TL98Q machine on a Gracie quilt frame with a Gracie Sure Stitch regulator. I can quilt for approx 30 seconds and then the needle thread breaks. I've adjusted the tenion in the bobbin, changed needles, adjusted the stitch length on the Juki, as well as the stitch regulator. Any suggestions? Thanks.
  • Anonymous Mar 17, 2014
    satin stitch on ambitions essentials--thread keeps breaking during stitching and thread not moving freely
  • Anonymous Mar 22, 2014
    needle breaks when i do the lock stitch. breaking a lot of needles
    New Friend:
  • 186 Answers
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 4 Answers
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
Posted on Jul 29, 2009
  • stevovegas Oct 18, 2010
    Try a spool of different thread. You may just have a spool of bad thread.
  • SandraDea Oct 29, 2010
    I use to have that problem also. Seems my machine only likes Maxi Lock cone thread. I have to make sure that the thread on the bobbin and the top thread are the same. For some reason it doesn't like all cotton, even the machine quilting thread seems to break or shred whne I use it, no matter what the tension was adjusted too. Then again I may have just got hold of old thread at my little store here. But so far Maxi Lock has been the best thread for this particular machine. Finicky I guess!
Are you sure the needle is in the right way? For an industrial machine, the groove in the needle should be facing left.
Posted on Apr 16, 2009
Bobbin does not stitch
Have you changed your needle lately? Have you checked the needle/shuttle timing?
Nov 02, 2012 | Juki TL-98Q
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
I have started quilting a large quilt and having problems with the bottom thread showing through at the hole puncture. My backing is purple and the bottom thread matches the purple color. My top is made...
Use a universal #10 needle. The smaller the hole from the needle the less you will see of the bottom thread showing on the top. And I'm sure your using good quality #50 weight cottom thread, right?
May 12, 2011 | Juki Sewing Machines
Juki TL98Q long arm quilting machine: can sew perfectly then all of a sudden a series stitiches are skipped. Why?
Using a long carpenter's level, level up your frame. Low areas in the frame can cause skipped stitches. Also, check the wheel sensor wheels-are they making good connection? These can lose connection when you quilt in certain directions.
Feb 13, 2011 | Juki TL-98Q
Machine sews fine when it is set up on a table, but when it is on the Gracie II quilting frame and operated by their stitch regulator, the stitch quality is very bad. It varies from fair to very bad - I...
Use a carpenter's level to level up your frame, and be sure to keep the quilt leveled up to barely above the throat plate on the machine, and level front to back. Check the connections on the regulator sensors. If even one is not making good connection, you'll have skipped or broken stitches.
Jan 24, 2011 | Juki TL-98Q
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Tension
Several things to try, I have this set up and after six months I'm still trying to get some issues resolved.  First make sure the machine is treaded correctly, the Juki doesn't thread like most machines, make sure you have the bobbin going the correct way.  After the machine then it has to be in the frame which means that the fabric is most likely to tight, this is a common problem, if you are bending the bars then it is too tight.  Also, look at how the quilt is in relationship to the frame, is it level?  As you quilt and roll, you will need to adjust the frame up, the quilted part should not drag on the machine and the to be quilted part should not be below the machine.  It is a critical that the frame and the machine be even with each other, if not the machine will try to pull and won't sew correctly.  Also, another tip, after each quilt change your needle, the reason is that free motion is technically bending the needle.  Hope all this helps.
Sep 09, 2008 | Juki TL-98Q
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Juki TL-98Q Logo
842 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
