I have a dayton torpedo heater. It will not start on its own, you have to spin the fan then plug it up real quick. It will work fine once it is going but you have to spin start it every time. Need help as to what needs replaced and what it looks like.
    Novelist:
  • 88 Answers
Looks like you need to replace the fan motor as it has gotten to the point of not starting on its own, I would bet the amp draw gotten a little bit to high and the motor windings have started to stick or fry, replacement of the fan motor is what I would recommend, hope that helps
Posted on Jan 20, 2009
Fan runs but no fire on igniter plug
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Dayton E51 Oil Filled Utility Heater
Have a Dayton model 2E510/a/b/c torpedo heater that I put in a new blower motor (old one was locked up). When i turn it on now the fan starts but then shuts down, then the fan tries to start again but...
Jowens8648,
All these types of heaters were made by the same manufacturer, Desa International. I would go to http://www.reddyparts.com . They would have any parts you would need and probably a repair manual.
Thanks for using Fixya and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 13, 2011 | Dayton E51 Oil Filled Utility Heater
Dayton Torpedo Heater starts then cuts off immediatly.
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Mar 27, 2010 | Dayton E51 Oil Filled Utility Heater
Have a 120000 btu fuel fired torpedo heater that fan spins and fuel drips but no spark
fuel is atomized by the blower fan, and a sparkplug provides the ignition source. this sparkplug provides constant ignition spark for the process.
Jan 03, 2010 | Dayton Heating & Cooling
Dayton 3EV51 torpedo heater
Dayton heaters at one time were manufactured by DESA or a predecessor and labeled DAYTON for Grainger. I have been unable to find any specific reference material to "Dayton 3EV51".
There were 2 types of motors used. I suspect your heater has a starter relay. The solid state relay was used to allow the energizing of the start winding which would allow the motor to achieve approx 80% of rated speed, then the relay would de-energize the start winding to prevent overheating. The relay is not attached to the motor, except for the wiring.
5ef4624.jpgThis is what the starter relay looks like. If yours has one check to see if it is energizing the starter windings at start-up. If not it is probably defective. The part is still available at www.reddyparts.com, I think, but today's replacement part looks slightly different.
If your motor does not have the relay, then the motor has an internal start-up system which is not serviceable, but the motor is probably still available. Most of the time the motor's part number is printed on the label.
Oct 11, 2008 | Dayton E51 Oil Filled Utility Heater
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
