Question about NAD T775
Overheated wont turn on
Amp was operating at high volume and overheated. i reset main power on back of amp and it now turns on but then immediately shuts off.
  • Steve Clements Jan 03, 2013
    The amp was on at high volume for long period of time. Shut down on its own. I could smell an odour from the unit. Like something burned. The power button on the rear resets the unit. It turns on with an orange display light on the front but almost immediately shuts down and the light on the front turns red.
3 Suggested Answers
gopakumarg43
  • 74136 Answers
SOURCE: NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Posted on Jan 24, 2012
palaboy
  • 5807 Answers
SOURCE: Amp shorts down during "Warm-up"
These needs repair.
Check for shorted drive / output transistor and associated circuits.
Posted on Aug 30, 2012
The standby power light is on but when I turn on the system it wont start up. It begins to with lighting up the volume lights but then shuts down again...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 24, 2011 | Audio Players & Recorders
MY vsx-820 receiver shuts off when I turn the volume up to a certain level. Appears to be overheating and auto shutting down. Solutions?
Sep 16, 2011 | Pioneer VSX820 51 Channels Receiver
Denon avr-1706 turns on, but then after start up goes immediately off. I also had similar problems with volume turned up too loud turning off the entire unit. What can be done?
Continuously stressing it with loud volume has succeeded in making an intermittent problem int a solid one.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 16, 2011 | Denon AVR-1706 Receiver
Was playing through my technics suv7 and volume cut out, has done this befor and when it dose i turn it off and on it would make a clicking sound then volume comes back , this time the power cut out and i...
It finally blew up.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 21, 2011 | Audio Players & Recorders
Lost sound suddenly. It seems that the power supply was gone.
What signs of life DOES it have?
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 01, 2011 | Denon AVR-1609 Receiver
I have a Harmon Kardon AVR 310. I turns on but no sound. I don't have the remote for it. I have done a reset but still no sound. Where should I go from here?
Or it could be self-proetcting...
Apr 24, 2011 | Harman Kardon AVR 310 Receiver
How do i check the fuse on an STR DH100 Reciever. Unit powers on but doesnt play sound
When a fuse blows its permanent.
You may have a control out of position or tt could be in self protection.
Turn the volume to something reasonable and see if that helped.--
Apr 19, 2011 | Sony STR-DH100 Receiver
What if went in safety mode, safety mode is froze in screen. Won't do anything
"Safety" mode - literally? I don't see that anywhere in the manual.
Page 13
Speaker Connection Precautions
(North American and Taiwan models) You can connect speakers with an impedance of between 6 and 16 ohms. If you use speakers with a lower impedance, and use the amplifier at high volume levels for a long period of time, the built-in amp protection circuit may be activated.
Page 66
The STANDBY indicator flashes red
The protection circuit has been activated. Remove the power cord from the wall outlet immediately.
Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and set the volume to maximum. If the AV receiver stays on, set the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your Onkyo dealer.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Apr 04, 2011 | Onkyo TX-SR608 Receiver
I own a RX-V1065 AV receiver. Whenever I turn the volume above a certain low volume level the receiver powers off. I can than turn it back on and continue watching my theater at a low volume. Anything...
If this just started happening I'd look for loose speaker wires or...
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 08, 2011 | Yamaha Audio Players & Recorders
I have a Sansui 717 Receiver/Amplifier. Everytime I turn on the power it will warm up for a few seconds...the blinking will stop and ready. I try to turn the volume up and it cuts out immediately. Can this...
Generally speaking, an amp protects itself from heat, shorts and overloads.
Jan 23, 2011 | Sansui Audio Players & Recorders
NAD T775 Logo
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
