Question about GE 46GW945 46" Rear Projection Television
Ge 46gw945 I have this model TV, and now the buttons on the front panel do not work. Also, the channels now will run through on their own. I cannot get it to stay on one channel. Can you help ?
I have the GE big screen tv - the batteries to my remote died - after changing them the remote no longer works - i have brought 5 different univeral remotes all for GE tvs - none of them work either - and i cannot seem to find my sensor on the front of my tv - also i no longer have he manual - please help
Posted on Dec 15, 2009
    President:
  • 3,130 Answers
You will need to get to the control board and see if any of the front panel buttons are sticking. if they are not, you will have a bad switch or the remote sensor is defective. If you have no TV repair experience. you will need to consult a pro to assist you with this repair. Good Luck
Posted on Jun 25, 2007
GE 46gw941
MOST likely a bad high voltage transformer or a Glycol leak both of which were common in this set and the parts for this set are nearly impossible to find (I think by the model number set is newer than 92).
I liked these sets but I would not invest big money to fix one this old.
May 20, 2012 | GE 46GW945 46" Rear Projection Television
I have a GE model 46GW945 and it will work fine
I have a 1997, 19inch GE TV it comes on for about 10 to 15 minutes then shuts off and will not come back on until a few hours go by or so?? Anything will help Thank You
Dec 18, 2009 | GE Televison & Video
Why does my GE 46GW945 46 in.TV turn on and then right back off?
this is weak power distribution throughout the unit. you wil need to test the power supply board for blown capacitors and resistors as well. replace this vital board if you notice any swollen or disscolored componets.
May 23, 2009 | GE 46GW945 46" Rear Projection Television
Sound but no picture
The first thing to check is the connections to your source. They can easily become loose and/or corroded over time.
Feb 25, 2009 | GE 46GW945 46" Rear Projection Television
GE 46GW945 46" Projection Color TV
Over the air channels 60 or above will all be gone soon. The space will be allocated to cell phones and such.
This may be what you are seeing.
Aug 10, 2008 | GE 46GW947 46" Rear Projection Television
Ge oct 1997 46gw945
I THINK YOU HAVE A BAD KEYBOARD--SOMETIMES THE KEYS STICK AND IT COULD CHANGE CHANNELS ,VOLUME GO UP AND DOWN,TURN ON ,OFF ETC.......GO TO A LOCAL SERVICER AND SEE IF HE CAN SELL YOU A USED ONE --YOU' LL KINDA SEE WHATS INVOLVED TO REPLACE--YOU MIGHT WANT TO TACKLE THIS IF TECHCANALLY SMART---ONE OF THE TRICKS IS TO "NOT TO BREAK THE OLD ONE WHEN REMOVING"" BE CARFULL...
Dec 12, 2007 | GE 46GW945 46" Rear Projection Television
HAS SOUND,NO PICTURE?
YOU'VE LOST VERTCAL DEFLECTION---THIS COULD BE SOME PARTS IN THE VERTICAL SECTION BAD,,LOST A VOLTAGE GOING TO THE CIRCUIT OR WORST CASE ----FLUID FROM THE PICTURE TUBES HAVE LEAKED ON THE CIR BOARDS CAUSING THIS PROBLEM---NEED TECH FOR THIS ONE!!!!!!!!!!!
Sep 15, 2007 | GE 46GW945 46" Rear Projection Television
TV acts like a timer is controling the power...comes on only at night
How old is this set? If any age, might be time for a replacement, you can get a 50" for under $1000 now. Dont know about your issue, I have never heard of one not turning on because of a timer, suspect you may have a micro issue, the power cord unplug would be advisable, but sounds like you tried it, have you tried the buttons on the front? Do you clean the screen with something liquid? Some of these the buttons go bad and confuse the micro if you use liquids on the screen and let some dribble down the frame. Might pull the speaker grill off and there should be 2 1/4" screws on 2 brackets loosen and the brackets will drop, the screen can come out and there is a long connector that goes from the front to just behind the middle tube and if you unplug it it will kill the buttons on the front and if it is your problem will allow the remote to function, reassemble reverse of disassembly.
Jun 18, 2007 | GE 46GW945 46" Rear Projection Television
GE 46GW945 Projection has color alignment problems after power outage
Try unplugging for 12 to 24 hours. if that doesnt help replace the convergence IC's
Sep 08, 2006 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
150 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
