Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
    New Friend:
    Problem Solver:
  • 14 Answers
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Posted on Jan 21, 2013
  • 13 Answers
SOURCE: I have a John Deere GX345 with a Kawasaki liquid
Sounds like you may have a problem with Choke adjustment, or perhaps a broken choke cable. Do you have a workshop manual?
Posted on Oct 25, 2010
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
wireguy212
  • 1627 Answers
SOURCE: i need a wiring diagram for a john deere 4500
What are you trying to repair?What on the tractor is not working?Copy right laws prevent me from posting the diagrams but i can help you with your problem,i have access to the diagrams you need so let me know what you need.
Posted on Jan 21, 2010
John deer gx75. 9hp kawasaki. Turns over but won't
check and clean air cleaner. Check main jet for blockage.
Jun 23, 2013 | Garden
1983 john deere 420 garden tractor thats stalling out when barely moving the hydrostactic lever or trying to engage the front or rear PTO
There are 2 safety switches on that unit as well. Most of them are right below the steering column in the firewall area. Search that to see if that unit has them. I'd be willing to bet one of them is faulty. Most are just a push button type.
Oct 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
John Deer tractor (JD301-A) won't start (no power at all) but if I unplug the carburator solenoid it cranks but it won't start. I need to move it to a roofed are, it is in the field. Is ther
yes a bad solenoid will shut it down if you put power direct to the solenoid and it still doesn't operate its bad with a grinder grind the tip off while your waiting for the new one just make sure you bring down to idle for a few min before shutting it off it a anti back fire solenoid
Sep 23, 2012 | Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
John deere x300 after restarting will not go foreward or reverse (hydrostatic trns) It starts and blades engage fine
Check the transmission disengadge lever located behind the transmission. Make sure it is pushed in all the way. Otherwise, make sure the traction belt from the motor to the transmission is on track. If this is not the fix, please respond for further instructions... I've been running the "X" series JD tractor since they came out!
Oct 07, 2011 | Garden
John deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Oct 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
358 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
