Have softwinerEvb android 4.0.4 cannot get it to make internet connection on talk talk wireless router
Although tablet knows the talk talk router is there and signal strength it cannot make a connection to it says authentication problem how do we make it work through the router? tried connecting to PC but windows cannot find software for the tablet
SOURCE: Failed to detect an internet connection
if you are having problems with your Linksys routers, reset the router and configure it again. In configuring the router, I suggest that you use the online tool that will automatically configure your router. It is similar with the setup cd but the online tool works better. The reason why the setup cd fails is that it has its own bugs. So just use the online tool. You can get the online tool on this website--www.linksys.com/easy.
Posted on Dec 21, 2007
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
Rajan Solank
  • 62 Answers
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
Posted on May 26, 2009
  • 108 Answers
SOURCE: Cannot connect wirelessly
One additional thing to the above, in the Internet Options Dialogue box.
Press sequence Alt, T, O to open Internet Options.
On the "Connections" tab, press "LAN Settings" button there.
On the box that pops up, be shure the checkbox is checked beside, "Automatically Detect Settings"
Posted on Aug 13, 2009
kakee
  • 1269 Answers
SOURCE: can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Posted on Oct 06, 2009
Testimonial: "Ah!Brilliant! This was fantastic instructions on how to fix such a really simple problem I had no idea I was having! "
How do I get it to stay connected to my wireless internet?
Resolving Internet connection problems - Belkin
www.belkin.com/us/support-article?articleNum=10823
BelkinFrom wireless home networking and entertainment, to mobile accessories, energy management, and an extensive range of cables. ... Sign In · Cart0 items; Free Ground Shipping on Orders through December - Details ... How do I find my model number?... Stay tuned for exclusive offers, exciting new products and more.
My android tablet won`t stay connected to wifi network ...
www.askmefast.com > ... > Wifi
My pc tablet wont stay connected to wifi internet help ... read more ... Someone said: i have a belkin router i have just put a security setting on it all the pcs work fine put in the password but my android ..... Ok it is a slow signal using other network .... Irulutablet doesnt work unless i m in the same room with the wireless router.
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Jan 05, 2016 | Irulu 9 inch Android Tablet PC, 4.2.2...
What kind of wifi remote/wireless do I need for a Samsung galaxy tablet?
If you have a combination modem/wireless router you should be able to connect your tablet to the internet. If not, you will need to either buy a wireless router that connects to your modem to broadcast the wireless signal or contact your service provider and get the combination modem/wireless router.
Dec 27, 2014 | Samsung Galaxy Tab 3 Lite SM-T110 8 GB...
My tablet doesnt want to connect to skype or the internet. It says "You cannot connect at this time." Help?
Try resetting your wireless router that you are using to connect to the internet. (unplug the power for 5 minutes).
Also tell your tablet to disconnect from the internet and then Reconnect a few seconds later.
Dec 21, 2014 | ProntoTec ntoTec 7 Inch Android Tablet Pc,...
Skype calls break after every 2 mins when talking on tablet
it could be a connection in between wireless router and your tablet.
if your tablet having ethernet port connection pls try with this port and make sure the fault in wireless connectivity. if yes pls try with change wireless sequrity and test again
Apr 08, 2013 | Computers & Internet
My softwinerEvb tablet freezes when i turn it on
press power and volume up once the dead android appears.
Then install adb driver for windows and plug your tablet to an usb port of your pc. Next find Livesuite for flashing allwinner A13 tablet with a new rom.
It doesn't work for me, but still working for many people on web...
Jan 29, 2013 | Universal SoftwinerEvb Capacitive Android
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
User Manual for SoftwinerEvb 7" Android Tablet
no encuentro el icono de utilerias para configurar la tableta
Nov 27, 2012 | Tablets & eReaders
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
I can access internet through wireless but cant access my iphone although it is conected with buffalo router but not accessing internet
I thought that the iPhone was connected to the internet thru IBM's cellular network, and did not
know how to talk to a wireless cable router at all.... note that the iPhone has no idea what
802.11n WiFi standard is... the iPhone uses 2 technologies to communicate with the AT&T network,
the iPhone 4G has two models, a CDMA model, and a GSM model...
IPhone reference: http://manuals.info.apple.com/en_US/iphone_user_guide.pdf
May 14, 2011 | Buffalo Technology Buffalo Wireless-N...
Computers & Internet Logo
357 people viewed this question
David Payne
David Payne
