Question about Food Processors
The lever onmy maestria m4000 magimix is stuck
Cleaning magimix handle
Magimix Food Processor and Bad Customer Service
fussfreeflavours.com/the-tale-of-the-magimix-and-bad-customer-service/
Jan 12, 2012 - Magimix food processor review - the exorbitant cost of replacement ...time to find out how to clean the internal part of my Magimix 5200 handle.
magimix compact clean handle Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your magimix compact clean handle question. Get free help, tips & support from top experts on magimix compact clean handle related issues.
Food processor - Magimix
www.magimix.uk.com/page/faq/Food-processor/CS-5200-XL/
Magimix UK : FAQ Frenquently asked questions - Food processor. ... direction until the locking tab engages the top of the bowl handle. ... Never exceed the quantities recommended for your food processor model in the instructions for use.
Amazon.co.uk: Customer Discussions: Food processor bowl to
Jan 01, 2016 | Magimix Food Processors
How to remove a stuck blade from a magimix
Correct repair is to replace both the blade and the motor shaft so drilling a hole sideways thru top of the blade to give you something to grip against is easiest. You need to protect the bowl because it's not necessary to replace that part. A couple of bits of wood across the top either side and then a screwdriver into each side of the hole you have drilled should give you enough grip to lever the blade off.
Sep 06, 2014 | Magimix 4200XL Chrome Food Processor...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
Need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Oct 30, 2009 | Magimix 5100 Cuisine Systeme Food...
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Food Processors Logo
23 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
