Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Will loose adjustment on valves cause skip and flooding or rich exhaust
TO-20 really burns rich & skips, can't seem to adjust carb to clear it up. Also has a light knock after it warms up & it is pulling but when not pulling, like coasting down hill idling it seems fine . No oil consumption. A buddy of mine said it could be a wrist pin. Anyone have any solutions. Thanks
  • lloyd gazaway Jan 10, 2013
    thanks kelly, i'll try this as soon as i get a chance.
4 Suggested Answers
  • 43 Answers
SOURCE: 150cc scooter runs but doesnt top out only about30
likely variator problems. Flat rollers?
Posted on Dec 31, 2009
SOURCE: to-20 skipping bad. i installed new plugs and now
i havent solved it yet. but like i said, pull the wire off and it stops. i switched wires too but it's still there. i switched plugs too. HELP
thanks. bill
i dony have money to pay you guys as i am on a very small income and i mean small
Posted on Feb 07, 2010
kel1guy2002
  • 3740 Answers
SOURCE: my WD seems to flood when it is being driven,
It sounds like during the rebuild the float level some how was changed to a higher setting. There is a tab on the float that needs to be bent in order to change when the float valve actually closes. Seems your float valve adjustment is allowing the carb fuel level to be too high which will create the exact symptom that you described.
If the level is fine then there can be a small piece of debris in the float valve seat.
Also.. if the float itself has filled with fuel it can be too heavy to float and cause the float level position to remain low even when the carb is full not allowing the fuel supply to be shut off. If the new o-ring for the float valve was cut during installation it can also cause your current symptom.
At this point I just think that a float level adjustment is all that should be required.
with the float bowl screws loose the bowl should never overflow in a static condition. If it does the float level adjustment is off.
Thanks for using FixYa.
Kelly
Posted on Mar 19, 2010
2010 sportsman 500 hd runs then dies turns over won't start
My opinion, it's running rich and letting it idle for 5 minutes doesn't help. Whether it's carbed or EFI, when the machine is cold, it needs more fuel. As engine temperature increases, it doesn't need as much fuel, and the carbon that started building up on the plug is burned back off. When a machine isn't ran for very long, carbon deposits continue to build on the plug. The carb itself may need to be rejetted/adjusted, it it's running rich,
Aug 12, 2014 | Polaris 2010 Sportsman 500 H.O
Skipping stitches
You don't mention changing needles to match the thread. There is NO SUCH thing as a universal needle. If you need lighter thread, you need a lighter needle. Start there...
Mar 19, 2013 | Sewing Machines
My vx 800 is flooding from the rear carb and blowing out exhaust. Should I just pull the carb and check float?
Your carbs will need to be cleaned adjusted and synced, but it also sounds like you need your valves adjusted.
Dec 03, 2012 | Motorcycles
Adjusting yamaha ew 50 carb
This can only be caused by one thing, dirt or a small peice of casting shard has gotten into one of the fuel or air bleed passages or jets, very easy to block them because they are very small holes. You will need to pull the carb off and clean it with carb spray and then blow out all the passages with compressed air, that is a must.
Dec 05, 2011 | Motorcycles
Carburetor idle mixture adjustment for lean burn chrysler engines
On a carbureted engine(the days of old) I had a method of my own
which always seemed to do really well.
Warm up the engine to operating temperature and make sure there is no
operation of the automatic choke.This should mean that the choke flap in the top of carb is standing vertically offering no resistance to airflow.
Hook up a tachometer if the car has'nt got one.
Note the idle speed in PARK.
Turn the fuel/air adjusting screw underneath carb's right or left sideI(NOT the idle speed set screw) IN and note the rpm as you do.If it raises a little,you are getting close.
Go ahead and turn that screw in all the way and lightly seat it(count the turns in from the highest idle reading),then back it out to the highest reading.NOW turn it in slowly until you see the RPM drop slightly.
Now back it out a little so you are at peak RPM again.
REPEAT this with the other side's fuel/air screw.
After you have gained this higher RPM (maybe), then set the idle speed control screw to desired RPM, and be sure to get in the car and while holding the brake,put the car in DRIVE to make sure the idle doesn't drop too low. don-ohio (:^)
Nov 17, 2011 | 1986 Chrysler Fifth Avenue
Cdp-ce315 skips in songs
My answer here only concerns if you're trying to play burned audio CDs. Burn your audio CDs at the lowest speed (1). Try the JVC/Taiyo Yuden brand.
Nov 09, 2011 | Sony CDP-CE315 5-Disc CD Changer
I have a 94 yz250 has plenty of power but is spitting oil and after about 20 min of riding goes dead but will crank back up right after. doesnt do it if I ajust the carb to run rich.
Spitting oil indicates that it is running rich. It could be down on compression which will cause it to run rich. The rings don't last forever in these bikes and need to be changed every once in a while to restore proper operation.
I am betting you are turning the air screw to "adjust" it to run rich as you stated. This screw only effects the lower RPM - it is actually a fine tuning screw to adjust the low end - specifically the pilot and needle jet. It has very limited effect on the jetting above maybe 1/2 throttle. The proper way to alter the way the carb acts is to physically change the jets in the carb. The pilot is for lower end performance, the needle is for the lower-mid range and the main is for mid to mostly upper RPM range. The float level also plays into all this.
To attempt to answer your problem - it could be that your spark plug is incapable of firing once it gets overheated. An overly rich mix will prevent it from doing it's job also and can burn a plug out. Try replacing it with a fresh plug and you might want to clean your air filter and check your compression. You should have at least 150PSI. I've seen bikes run with as little as 95PSI but they run poorly and are hard to start.
Oct 22, 2011 | 2003 Yamaha YZ 250
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
I have a 1981 650 gs650 motorcycle I have cleaned the carbs 3 times installed new needle and seat. air cleaner is clean. valves were checked for clearence have good fire but it is still running rich and...
The carbs have to be jetted. If they are the slightest bit out, it will backfire, burn your eyeballs from the fumes and skip and sput like crazy. I found the Dyna-Flow adjustable kits work great, the should have one for your bike, I found one on ebay, because after going to Italy (Ducati) and getting the factory setting jets put back in the bike, it still wouldn't run. I took those carbs off 20 times, the first time took me an hour, I can get them off there now in 10 minuets. Anyway, the adjustable jets work great, it fired right up and ran perfect the first time. Still running great. I am sold. Check them out.
Aug 08, 2010 | 1981 Suzuki GS 750 L
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
51 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
