Question about Pride Value Line Revo Scooter 3 Wheel
The manual freewheel lever will not go into gear
The light flashes 7 times, stops, then repeats. scooters in gear but wont go
  • Pride Master
  • 1,271 Answers
Hi, 7 flashes implies the throttle lever (speed pot etc) is not in the correct position, other words not dead center, (PGDrives S -Drive Controller)
Let me explain , the pot in question is a 5K value and the throttle lever rests in the center of that about 2.5k give and take
If you can see the bottom of the metal stem in with the throttle lever is mounted there should be a cross head slot now that should be dead center, the slot facing you as you sit on the scooter, slightly off center will cause the fault reported.
Regards
www.gewizrepairs.co.uk
Please rate my assistance.
Posted on Jan 02, 2013
2 Suggested Answers
  • 16 Answers
SOURCE: pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Posted on Aug 01, 2010
I have a elite mobility scooter why does it stop on me my battery are fully charged the lights go on but won't move
Hi check freewheel lever at the rear of scooter if U an push the scooter it's in freewheel :::::: push the lever lever the other way to lock it in gear .. Cheers
Nov 25, 2016 | Elite Health & Beauty
I have a shoprider dulux and all lights work all fuses work but scooter wont move forward or back checked the free roll lever and break they both good and in right position please help
Hi just check to c if U have freewheel lever in correct position if U can push the scooter it's in freewheel ,::::::: push the lever the other way so it locks into gear check to c if it's locking in gear :::: if U can't push it it's in the correct position,.., Cheers
Nov 22, 2016 | Shoprider Health & Beauty
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Celebrity x mobility scooter . error code 5
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
May 27, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Controller light is flashing and chair will not move
Sandi Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. This will give you the flash error code and your users manual should tell you what the number of flashes indicate. (for example 3 flashes bad brake) Also check to make sure your scooter is not in freewheel. Turn off the scooter and move the freewheel lever in and out of gear a few times then turn the scooter on and see if you still get the flashes. If you can't figure out what is wrong then contact your provider and ask if they can check it out for you. Hope this Helps
Oct 03, 2010 | Pride Go Chair Travel Power Chair
Led Flashes 5 times - Brake in freewheel or brake connection problem. How can I fix this?
Pull the key out of the plug or key switch. There is a freewheel/brake release lever sticking out of the top or back of your scooter on the driver's right hand side. Push this handle the opposite way it is now and try the scooter. If this does not work, repeat the steps above. It is important to do this with the key out of the unit or it will not reset.
May 10, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Pride celebrity 4 wheel wont turn on
Hi
Gerry.
Nov 02, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride Value Line Revo Scooter 3 Wheel Logo
186 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
