Question about Cooper Wiring Devices Combination Switch & Receptacle
HOW DO I WIRE IT
WHAT IS THE WIRING PROCEDURE FOR THE COOPER COMBINATION SWITCH/GFC1 VGFS15
4 Suggested Answers
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Posted on Jan 29, 2010
  • 351 Answers
SOURCE: i have cooper combination switch and gfci out let
Hi ,., the two screws on the one side of the combo are for the white , neutral wires, they should be interconnected with a small link. The screw at the bottom of the switch connect the black power wire, then jumper a wire between the other two screws on that side and the switch will be controlling the receptacle.
Posted on May 04, 2010
dgw1
  • 19 Answers
SOURCE: I have a Cooper 7503W-Box
The other two are travelers and if the circuit was previously hooked up correctly you can connect the white and red to either screw.
Posted on Mar 03, 2011
Do you have to break off tab when installing combination device
The switch/receptacle pictured can be wired a number of ways. If you want to switch the attached receptacle you will leave the tab on between the brass colored screws and attach your HOT wire to the brass screw on the opposite side. The bare or green ground wire will attach to the ground screw. The white Neutral wire will attach to the silver colored screw.
Dec 31, 2013 | Cooper Wiring Devices Combination Switch &...
Trying to wire switch and plug combination where the switch will turn off the plug
Black wire to brass connection on switch. White wire to silver connector on receptacle. Add a wire from the silver side of switch to the brass side of the receptacle. When switch is on current flows through to it to receptacle then out white when something is connected to the receptacle.
Nov 19, 2013 | Cooper Wiring Devices Combination Switch &...
Cooper tr274v wiring diagram
Are you installing a combination switch-outlet?
What are you replacing? A switch? Is switch single pole or 3-way?
Or are you replacing outlet.
Do you have the Cooper TR274V?
Which device do you have?
http://waterheatertimer.org/How-to-Replace-outlet-with-combo-switch.html
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
http://waterheatertimer.org/How-to-wire-switches.html#5245
Gene
hh
Oct 02, 2013 | Electrical Supplies
What's your problem? install a cooper os106d1
Motion sensing switches wire identically to in-wall timers:
Copy following link for different wiring options depending on the switch that is being replaced:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
Copy following link to see illustrations of switch wiring, including motion detector, combination switch, and 3-way switches, double switches etc
Jun 13, 2012 | Cooper Wiring Devices Motion Sensing...
I need a wiring diagram for VGFS15-MSP combination switch/GFCI
Copy following for wiring diagrams showing GFCI combo switch-outlet
http://waterheatertimer.org/How-to-wire-GFCI.html
Dec 04, 2011 | Electrical Supplies
I have a light switch like this, I have 2 black wires and 2 white wires only. THe house was built in the 60's, I found I black wire that is constantly hot, how do I wire up the plug,light switch so...
Bit more information is needed.
Wire color is not as important as knowing what wire is for.
Knowing Hot black hot wire is good step.
Next, see if box has neutral wires. Neutrals are usually white wires that are twisted together and covered with wire nut. Test black hot to each white wire to find neutral.
If box does not have neutrals, then this device cannot be wired to code.
Other black wire probably goes to light.
Open following link for illustration of wiring:
Aug 01, 2011 | Cooper Industries Cooper Wiring 274W...
I have cooper combination switch and gfci out let they gave directions for gfci outlets how do you wire it using the switch o control the outlet
May 02, 2010 | Cooper Wiring Devices 274LA DECORATOR SP...
How to wire 4 prawn 250 volt plug
The 2 wires coming off the double breaker should go to the x & y of the plug. The ground should go to ground (green or bare) and the other prawn left over is the neutral wire, it goes to the buss bar in the breaker box with the grounds ( usually with a bunch of white wires )
Apr 05, 2009 | Cooper Wiring Devices ACE AC-DC...
Cooper Wiring Devices Combination Switch & Receptacle Logo
37 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
