Gaffers and Sattler furnace doesn't turn on
Pilot is working fine. thermostat doesn't appear to be the problem. Not sure what to check before calling the repair dude.
5 Suggested Answers
  • 1033 Answers
SOURCE: Furnace won't turn on
What is the make and model# of your Furnace? And is it a pilot light, or a hot surface Igniter?
Posted on Dec 29, 2012
wcrawf11
  • 52 Answers
SOURCE: Hello I have a Gaffers and Sattler HVAC System the
If you can see the gas valve there is a thin hard wire called a thermocouple that comes from the gas valve and ends uo in front of the pilot light and this is where you would relight the pilot if the pilot wont stay lit then you need to replace the thermocouple you can get one from any hard ware store
Posted on Nov 28, 2009
james3751
  • 614 Answers
SOURCE: Have a Gaffers and Sattler furnace mod # 85 FDF
When it call for heat you need a voltmeter to see if you have voltage at your gas valve. Check that first. You could jumper your stat between w and r to see if you have a bad stat. Rus
  • 42880 Answers
SOURCE: Furnace doesn't turn on.
When I experienced the symptoms you describe the problem turned out to be the igniter.
?Location and photo of the transformer for a gaffers and sattler wall furnace model S 90 FE.
No. The transformer "transforms" 240 volts to 24. Meaning the high voltage coming into the machine. Normally has a "c",208,240 written on one side. Follow your main power wire into the machine. Branches to heater and transformer. Look at wiring diagram
Mar 01, 2017 | Heating & Cooling
I have a gaffers and sattler u100. The heater and fan work but the fan never turns off. PG&E says it's a wiring issue at the furnace, not the thermostat. Any ideas? Thanks!
There is a "Klixon" switch mounted to the heat chamber that is stuck closed. It will be wired in series directly into the motor wires
Dec 21, 2016 | Heating & Cooling
Where is the reset on an old Gaffers and Sattler furnace
on my old furnace (gravity) there is a overheat relay which will shut off the furnace if it is very cold and it overheats. it is at the top of the furnace box on the side with a pipe coming out to a relay box.....it needs resetting.....if its like mine with a pilot light...
Dec 20, 2013 | TPMS Scan Tool with TPR Reset Tool Kit...
Dec 29, 2012 | Heating & Cooling
HEATING ELEMENT GAFFERS & SATTLER BUILT-IN OVEN
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Have a Gaffers and Sattler furnace mod # 85 FDF ser # PV 09020. Pilot is lit, when I call for heat nothing happens. T-stat is okay, thermo couple okay/new. Fan will run when manually turned on at unit with...
Nov 28, 2009 | Heating & Cooling
Hello I have a Gaffers and Sattler HVAC System the wind has blown out my pilot and I cant seem to locate were to relite
Nov 27, 2009 | Heating & Cooling
Can't find the oven pilot on an old Gaffers and Sattler "Energy Saver Range with Uni Burners"
With the help from your site I was able to hold a match under the bar under the oven shelf toward the back and light the pilot. I am SO grateful. I hadn't been able to see it but just held a match toward the back, and it lit.
Feb 27, 2009 | Garland H283 Gas Kitchen Range
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Heating & Cooling Logo
183 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
