Question about Jensen JTA460 Turntable
Jensen turntable will not turn on - Jensen JTA460 Turntable
Can my turntable be adjusted
Jody, the arm the needle is on, usually adjustable with a dial on the end that can lighten, or put more weight on needle to help it track better on records. Other then that, the belts normally are changed to address slow speed issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JTA 220 Instruction Manual Page 2
http://audio.manualsonline.com/manuals/mfg/jensen/jta220.html
How To Calibrate Your Turntable For the Best Possible Sound
How to Adjust Tracking Force
Apr 09, 2016 | Jensen Jta-220 3-speed Stereo Turntable...
My jensen three speed turntable is not spinning my record
If it is a belt driven model it might have fallen off. If you lift up the turntable matt it should show a hole to view the belt. If the belt is good, it could be that a switch is not engaging when the arm moves out to the record, if it is the type that starts when the arm is placed on the record.
Mar 09, 2016 | Jensen Audio Players & Recorders
Blown speaker
Swap the speakers around to make certain it's the amp that causing the problem. Since stereo amps are two mono amps put together you have one good channel to compare the other one with. Sometimes a visual inspection will show what's wrong with it.
Jul 10, 2013 | Jensen JTA460 Turntable
Jensen JTA-460 will not power ON?
It may start when the tonearm is lifted. If not, the turntable may have failed
Dec 26, 2012 | Jensen JTA460 Turntable
I need it now jensen jt a 460 turn table manual
Tech Help call 1800 686 079 Mon -Fri 9am to 5pm I have a JTA 380 Manual ? similar spec's.
Mar 11, 2012 | Jensen JTA460 Turntable
Would like to know if the jensen jta-450 can be connected directly to my computer, if so, how?
Yes, it can. Just connect the RCA LINE OUT from it to the Line IN from the pc with a cable like
http://www.amazon.com/Dayton-3-5RCA-12-3-5mm-Stereo-Cable/dp/B000F7P7EW
Then to pick up the sound just use any recording program you want. I use
http://www.roemersoftware.com/free-sound-recorder.html
Jul 28, 2011 | Audiovox Jensen JTA450 Turntable
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
Changin turntable needle
If you just want to replace the needle / stylus, all you have to do is pull it out. It will be on there nice and tight, so be cautious. Don't pull the needle itself, instead, the housing where the needle is attached. This, in turn, is connected to the cartridge, which is connected to the tonearm. Here is a diagram:
<img src="http://1200s.com/images/Support/standardmountcart.jpg">
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Sep 08, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen JTA460 Turntable Logo
26 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
