Question about RCA L42WD22 42 in. LCD Television
Power lite on rca flat screen flashes 4 times
Power liteflashes 4 times, have unplugged to try to reset several times lite comes on green the starts flashing 4 times again, tv does not come on
  • RCA Master
  • 8,617 Answers
I would suspect either the Power supply or the main board. I can assist you with basic trouble shooting to determine which board it is if you would like. Just respond to this same post for assistance.
Posted on Jan 01, 2013
  • 4 Answers
SOURCE: green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Posted on Nov 25, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
  • 8457 Answers
SOURCE: RCA L37WD12 out of control
Ur Tuner board have problems,just not dead yet.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.The Tuner board main IC have intermitten short,that why take out A/C power input work for awhile,and than back to the same problems.
Posted on Apr 22, 2010
  • 277 Answers
SOURCE: rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Posted on Jul 21, 2010
pjhislay1
  • 822 Answers
SOURCE: My RCA 42" HD flat
sounds like it needs new caps on the power supply board..............easy fix if you can use a soldering iron........
cheers
Posted on Apr 07, 2011
Why would a red light be flashing instead of powering on?
The power supply keeps trying to start but can't.
Jun 22, 2014 | RCA Televison & Video
Sanyo hdtv lcd flat screen--no picture and no sound
first just for trying--unplug set for a few minutes and plug it back to see if it resets.
If not someone will have to open set and check voltages on Power board to see if there or not.
There is another issue common if set 1-2 years old but that is the set at first has to be turned on several times to get it on--let me know if you had that one and I will still advise you.
Mar 19, 2012 | Sanyo Televison & Video
Tv wont turn on but green power lite flashes 3 times if i use the remote or press power button on front of tv i have unplugged tv replaced the batteries in remote trouble started 2 weeks ago if i hold...
it sounds like youre describing a RCA HDTV which needs the CP150, CP120 and CP114 repair kit. You can get that repair kit at www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Sep 22, 2009 | Televison & Video
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tv will not turn on. green lite for 4 secs, 3 times, then off. D52W20
It could be several issues from a bag power supply, the TV is connected to a power strip with several other components hooked up (DVD, Sound System, Xbox, etc.).
Try connecting to the wall directly and see if it now starts up.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA L42WD22 42 in. LCD Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
