Question about Garden
Lawn tractor not getting gas in gas lines - Garden
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Check for plugs in gas line and don't use ethanol because it can plug up your gas lines too.
Posted on Jan 03, 2013
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wadembly
  • 475 Answers
SOURCE: engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Posted on Jul 25, 2009
SOURCE: ryobi lawn tractor mtd the problem is it begins
might also be starving for fuel. Make sure the gap cap's vent hole is not clogged. clean it out with a pin
Posted on Nov 07, 2009
  • 143 Answers
SOURCE: I have a craftsman lawn tractor that has an
Try blowing air back through the pipe into the tank, sometimes this works and its easier than removing the tank. Stephen.
Posted on Nov 10, 2009
John Deere 160 lawn tractor.
May have online fuel filter in line, need to check. Also could be wear in throttle shaft or housing in carburetor.
Aug 12, 2017 | John Deere Garden
24 hp Craftsman lawn tractor will not start; doesn't appear to be getting gas in the carb. It is pumping through the fuel pump.
hi Vet68652, I have to agree with tomicamel, it does sound like a clogged fuel filter there is nothing else between the pump and the carb.... unless the line is clogged,
Mar 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
No gas in gasfilter when line is opened no gas comes thru gas line from tank
take line off of tank, if it flows then it is the line, if not the the tank is clogged Tim
May 27, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
How to drain the old gas from my 20.0 HP, 42 in. lawn tractor. Thank you, Nancy
Remove the fuel line from the engine and drain the old fuel into a container. Follow the fuel line from the fuel tank to the engine. Anywhere along that line where you can disconnect it do so. The fuel filter is a good place to disconnect it and then you can replace the fuel filter when you connect it back up.
Apr 23, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 24 hp 42" Craftsman lawn tractor, after about 30 min. it lose power and stalls.
Hi;
Not sure this is the answer for your problem but here are a couple of suggestions.
Sounds to me like your getting a vaccum on your fuel line. Be sure your gas tank cap is able to breath. There is a vent hole in the cap, or should be.
I have also seen fuel lines collasp inside of the line. There is a center section of fule line that has been known to collasp and not let fuel thru. Hope this is of some help to you
Sep 24, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine wont fire has spark gas not getting thruogh
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
