Question about Ariens 34 In. Zoom Series Riding Mower
Engine Dies When Auger Engaged
I have an older Ariens snowblower that started running fine this season, then started to sputter out and die. If you start it it runs fine but when you try and engage the auger it dies. Any suggestions?
2 Suggested Answers
HW_Dude
  • 87 Answers
SOURCE: snow blower starts right up but dies once i engage the blades?
it is possible the engine is starving for fuel, so essentially it is a carburetor problem with fuel mixture.
Check and see if your carburetor has mixture adjustment needles, there may be an adjustment possible to fix this problem.
Also, sometimes a tiny vent hole in the carb caseing gets clogged causing the engine to run rough or stall.
Does your engine seem to run better if you close the Choke ?
Hope this helps you.
Posted on Jan 11, 2009
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Troybilt 2840 snowblower runs 5 or 10 minutes than dies
fuel tank not venting and the float levels falls to low
Nov 06, 2017 | Motorcycles
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Bough Sno-Tek 24 in. Two-Stage Electric Start Gas Snow Blower - under 2 feet of snow and engine dies when Auger is enagaged! Hope someone can help.
Jan 28, 2009 | Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Snow blower starts right up but dies once i engage the blades?
if its a 2 stroke (gas oil mix) there is an air leak in the crank case. a new gaskit is in order
Dec 30, 2008 | Ariens 34 In. Zoom Series Riding Mower
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
738 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
