Question about Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
How to remove ammo box for nerd Vulcan ebf-25
Need to know color code on wireing plugs that go into the side of fuse box, there are two plugs on 1998 kawasaki vulcan 750
Kawasaki Vulcan service manuals ' VulcanRider.se, English
www.vulcanrider.se/en/kawasaki-vulcan-service-manuals/If you like to download the manual(s) for later use, please right click on the ... if you like to contribute with a Kawasaki Vulcan manual not available below, please ... about 60 MB .pdf file · 1998-1999 Vulcan 1500 Nomad, 423 pages, about 25 ... Vulcan 800, 405 pages, about 176 MB .pdf file · 1985-2006 Vulcan 750, 2395(!) ...
images for 1998 kawasaki vulcan 750 wiring
Oct 29, 2015 | kawasaki Motorcycles
Once the plug is on the bolt (Fig 3 in instuctions) is there anyway to get it off again??
rcdodge posted the same problem on Aug 15, 2011. I've just posted a solution aginst his question, so try that (it's a bit tricky though).
Oct 25, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Im a fanatic of resident evil 1. i use chris as my player in resident evil in the mansion/ how could i get a infinite ammo from the start of the game. im getting always game over for always shortest of...
Well after some searching i found you can get infinate ammo for the grenade launcher (i dont remember how far in you get this) here is the glitch
This glitch only works with Jill. Equip the Grenade Launcher in the first slot (upper-most left) and then go to any item box. Select any grenade ammo in an item box slot that is different than the grenade type loaded in the Grenade Launcher. Next, attempt to place the grenade ammo from the item box into Jill's inventory; instead of "swapping items" the Grenade Launcher will swap ammunition instead.
Warning: After this glitch is done, you should divide your grenade ammo into the minimum nubmer of slots it needs (255 rounds per slot) to avoid corrupting your game data.
Source: Ign
Jul 03, 2011 | Video Game Consoles & Games
I put my battery pack in backwords and i cant get it back out
Can you try wedging something in there to use as a lever, like a screw driver or a butter knife?
Mar 14, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
There is a gray battery cover a little bit above the trigger. You will see a screw hole
Jan 02, 2010 | Nerf Secret Strike As 1
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
In Gears of War 2, when I get ammo after I die, why is it reduced
this was just a simple glitch that was solved by the recent patch update.
Before you died you have less ammo so it seemed as if you were gettting more m when you spawn you get more ammo and some ammo boxes don't give your gun max ammo where some did ( that was the glitch)
Mar 15, 2009 | Microsoft Gears of War 2 for Xbox 360
Hasbro Nerf N-Strike Vulcan EBF-25 Blaster Logo
Top Hasbro Toys Experts
thegtw
Spidey28
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
